Murf, dirf, whatever question.
Salt Lake City, UT
OK, on the inside of the knuckles, on the top, there is a square peg in a round hole. It seems to me like this is where you top off on grease. The question is however, how much do you grease up? I suppose that you just don't fill it up until the thing pukes. Right?
When you do the normal axle service, I the FSM says to pack 3/4 full, so that would be a good goal.
From what several people have posted, it sounds like the grease pumped in the square plug, will get mixed in to the rest of the knuckle.
Grease plug?
Has anyone taken the plug out, tapped a grease fitting into it and then just used that to fill the thing? I would think that doing that would minimize dirt falling in and all around make the process easier.
As far as the air, well that would work it's way out eventually.
murf, dirf, whatever
You rang? :grinpimp:
I made a plug with a zirk fitting, It works great, It takes a while but thats the grease guns fault.
I think that putting in a zerk would cause undue pressure inside the knuckle, possibly causing the inner axle oil seal to fail. This has been discussed several times by far more experienced people than I. You all are probably more experienced than I am, so do whatever you want to. If it works for you, great!
I just think it would be better to get one of those grease injector needles to get grease down in there. Good luck!
yes...search around...there's a thread out there
I have seen the birfield get drilled, tapped and a zerk installed. It was done to line up with the full port and they could grease the birfield directly.
If the grease can get out to the spindle/hub area its proof to me that one of my ideas will work. I want to apply slight air pressure via a line to the hole that the plug goes in. This will mean that when fording the pressure in the birfield and hub is higher than the water pressure trying to get in to mix with the grease.
