Mufflers - Who Needs Em?!
Kennett Square, PA
Website
cruisin4parts.com
So, a problem that has been irking me since the summer began is my dumb stock muffler. Yeah, that big over sized tin can under your 80..interestingly enough, its parked right next to the drive shaft.
So, I backed into something and I bent the tail pipe:
- Tail Pipe Hangs half way to the ground.
- The part that goes over the differential is slightly kinked from being pushed up against the diff when the tail pipe hit the dirt.
- The Muffler hangs and is pushed into my drive shaft. RUBBING and CLANGING WITH EVERYTHING ACCELERATION. :mad:
I'm not sure what to do. :confused:
... shoulda got a lift kit..:princess:
I had straight piped my cats and went with a performance muffler on my 3FE with bigger pipe. It sounded awesome. I must have got asked a 100 times about what V8 I put in it. My 1FZ sounds like crap with the cats and a similar high performance muffler.
What muffler were you running, my glasspack sucks.
x2?
My stock exhaust sounds pretty deep, but it's not very noticeable. I want it to be noticeable. No glasspack/rice rocket stuff for me.
I loved the glasspack with cats, gutted or stock. Not loud at all unless you really get on it. Sounded awesome! Only when I went with straight pipes did it start to sound obnoxious and crappy. I'm thinking a flowmaster 40 will tone it down somewhere reasonable...maybe a 50 to not be quite so loud.
I don't like the ricer/angry bee sound that a glasspack usually makes. I'm thinking catback... but ditch the Y-pipe and going duals all the way back, dual-in dual-out muffler...preferably flowmaster.
Do you know a good price on a 40 series dual-in dual-out muffler?
I'm running a 3" Magnaflow from the cat back. After I had it put on it was a little to rasspy, so I added a resonator about 12" from the tip. Much better now. I'll try to post up some picks soon. I think Flowmaster or Magnaflow sounds a little deeper in tone...hope this helps. Magnaflow is also stainless steel, may last a little longer.
:beer:
Magnaflow ss packed muffler for me, and sounded like a Honda Civic with a fart bomb muffler at hwy. Low rpm was fine, and even hard acceleration it reminded me of wife's Z, but the drone at 75mph was too much - threw a cherrybomb turbo on after it.
My rig sounds like a F16 without the muffler on! I drove it that way a while when we were switching exhaust systems, deafeningly loud decibels!
or you can do what i'm doing now and get a bunch of hose clamps and clamp it up out of the way for a while, until one of the clamps breaks from heat cycles and then it starts to rattle again so you have to go get another clamp, ect.....
i went down to a local muffler shop in my neighborhood, an the dude working there told me that a flowmaster 40 wouldn't fit under there. his explanation was that because oem is round and the flowmaster was flat. i was thinking, what a croc of $hizzle. he tried to sell me a flowmaster hushpower at an exorbant price. i just walked out of there and never set foot in that place ever again...
looking for another muffler shop.
I broke the muffler mount and cat mount. The muffler shop told me the metal is too rusty to weld, that the welder would just blow the old metal away. I ended up just trying them up there until I can come up with a way to fix em.
It won't fit without rerouting the tailpipe. It's not so much that it's flat, it's that it has an offset inlet-outlet, so you can't just chop out the center in center out one out and put in a flowmaster, or Turbo, or any of the others that is of that configuration. There is a different serries (70?) that you can get a center in center out flowmaster. I thought about trying out one of the edelbrocks for that reason, but ended up going with the magnaflow, which I regretted. And I ended up having to have a tailpipe made anyway cause the bend out of the stock muffler is so close to the muffler itself, you can't cut it then clamp the new muffler over it and get a decent seal. I was trying to do as much of it myself as possible, in retrospect, should have just spent the money and had it done for me. After I had the tailpipe put on, it sounded somewhat better inside, just cause it wasn't leaking after the muffler, but still didn't like the sound, so I cut the tailpipe and put that turbo in there.
