Mpg Problem!
I knwo these cruiser arn't hybrids but yesterday i put in 8.1 gallons and had at least a couple agllons in there at the time. so probably 10 gallons total. Coming home on the highway i ran out of gas at 78 miles on the trip meter! My cruiser is a 91, stock with 35's, Cruiser has rough idle cold, runs good warmed up but seems liek it has a miss every now and then at idle, runs good anywhere above idle. What do i need to look at hear, no check engine light or anything!
https://forum.ih8mud.com/showthread.php?t=170531
I just finished beating my head against this. I did alot (see thread) but the final solution which seems to have also restored my 13mpg city (I was down to 8.5) was the freaking negative battery cable end, yes a 3.00 part!
If I had it to do over thats where I'd start.
You say it's got a rough idle? Check the intake tube. It might be cracked, causing a vacuum leak.
A stock-geared 3FE pushing 35 inch tires can't be a fuel mileage champ. I'd be surpised if it would get 10 mpg.
10mpg would be better than the 7-8 i have now lol . Maybe this is the way it is supposed to be? I will probably be selling soon for a 01-04 z71 tahoe or maybe a f-250 , something that will get decent mpg.
What you save on gas you will spend on repairs with those ultr-reliable Chevs and Fords.
well the turbo diesel ford is pretty reliable, as is the tahoe. the land cruiser just doesn't seem like a practicle vehicle at all. The newer tahoe has more features, rides better, has 3 rows of seats too, and at 14-20 mpg does alot better in gas. Not to mention faster and not underpowered. Only thing the cruiser has going for it is off road ability, and if that is all it has it is better suited for just off road use. I am not really worried about really long term reliability, i don't plan on putting more than 30,000 miles on any of my cars i get
I have no help for the orig question sorry. Bad gas maybe? like that 10% E stuff?? I'd loose 3mpg on my 89 when I used that junk.
However, I just got 17.4mpg on my 94 on a 240 mile trip and I had about an hour of stopped traffic. All factory and in need of a tune.
Have a good day. :)
bob
With larger tires, your speedo will be off.
On mt 87fj60, I had 33x9.50x15 tires. The speedo was off 17%.
I would assume your speedo is off even more.
But you may as well sell the lc and get a Stupidaru, you will look better at the mall:flipoff2:
