CEL 26 rough idle runs fine above 1500 RPM
Westwood, Ca/Ixtapa MX/Ahwatukee, Az
My truck has CEL 26, per the list this indicates running rich. It has rough idle below 1500 runs fine above 1500 RPM. I just drove back from L.A. When I reset the cel & kept is at freeway speeds no light. When I slowed down or stopped for over 2 minutes CEL 26.
I have replaced the Cap, rotor, plugs, wires, Alternator, starter & Head Gasket in the last 2.5 months.
Please point me to the possible parts needing attention.
Thanks
wiring harness near the EGR valve...I would search as this harness is a common issue.
Thanks. The first two posts I found lead me to more newly replaced items: Fuel filter, Intake "tube" & PCV valve grommet & hose.
I'll look at the wiring harness from the egr.
all possible, just a line of troubleshooting...have seen issues with strange idel, etc with frayed wires due to heat exposure in the harness...
From the FSM, FWIW......
Code 26
(1) Heated oxygen sensor output
at 2,000 rpm is less than 0.45 V for
at least 90 seconds when¿warmed
up. Applies only to
code 25 and for California
models, excepting high-¿altitude
areas.
(2) When the engine speed
varies¿by more than 15 rpm over
the¿preceding crank angle period
during a period of 30
seconds¿during idling with the
intake air,
¿temp. 0C (32F) or above.
(3) When the difference between
the air-fuel ratio feed back compensation
value of the front¿and
rear exceeds 15% of the¿two
values in a period of 10¿seconds
while the engine
speed is 2,000 rpm or more
and the engine coolant temp. is ’
between 70C (158F) and
95C (2030F). ’
*6 (2 trip detection logic) (1) - (3)
Trouble areas:
Engine ground bolt loose
Open in E 1 circuit
Injector circuit
Injector
Fuel line pressure
ECT sensor
Compression pressure
ECM
Just came back in from checking it throughly (printed out egr pages of fsm) followed all procedures & all is as it should be. The wiring harnesses in the area are pristine. I let it idle for three minutes and no CEL. Shut it off for a few minutes let it idle again no cel but low idle & it smells rich.
Any ideas?
Thanks
My truck also suffers from a rough idle, and throws a code 26 sporadically. Their was another thread about a member whose truck wouldn't start after a suspension install and was traced back to corrosion on a fusible link attached to the battery... The harness is the next likely candidate, most mention around the EGR valve underneath the plastic cover and a few mentioned the lower firewall portion. Guess it wouldn't be a bad idea to check the wires for the oxygen sensors either.
I am going to do plugs, wires, cap, rotor and check the above mentioned obvious areas on mine whenever time allows it.
Just came back from a short drive. New symptom: Immediately after startup idle is fine, no CEL, on take off bogging like a dirty carb that is chocked out. Temp gauge took over a minute to move, (usually is almost immediately @ operating temp as it is 95 degrees out)
No CEL after the truck warmed up it drove normally. I left it idling for 10 minutes 650 normal idle, no rough running normal operation.
I am letting it cool back down then will see if the weird operation recurs. This reminds me of another new part: Thermostat.
Ideas?
This morning I got in hoping it would run normally and it did. Started right up. ran fine. I foolishly thought I was ok. No. Sitting at a light for about two minutes I look down CEL. Check the code 26.
GRRRRRRRRRRRR
Took it to the mechanic this morning. Ran perfect no idle issues no CEL. He connected it to his $6k diag & no issue. He thought the temp sensor was "sluggish" and that that was the issue but it refused to throw a code or run rough. Went home, got gas went to the market running fine.
I began to think it was ok & then CEL! WITHOUT rough idle. Code 26. I am going back (per his instruction)
I forgot to remove the paper clip & it is running @ a higher rpm (850-900 vs 450-600, is it ok to drive like this?
My recent CEL 26 was a wiring problem on one of the O2 sensors. Upon searching I discovered a few other peoples CEL 26 were found to be the same thing. Intermittent wiring on one of the O2. Its worth tracing those O2 wires from the sensor up to see if you have any frayed/exposed/cooked wires.
Did plugs and wires on my '94, then checked the O2 sensor.. BINGO.
Went through some flooded roads awhile back and guess water made it's way into the connector and stayed their. Afterwards the truck started running rough when at stoplights and such, an odd issue... The '94 only has one o2 sensor right?
My 94 has two. I had them replaced about four months (and -2000 miles ago) I bought all the wiring supplies I need to open up the harnesses & check the wires and properly tape them back up/solder/shrink tube them back together should I find a faulty wire.
It was in the 90's at 7am & was 108 at the highest today so I plan on going out to the garage about 5am tomorrow when hopefully it'll only be 85.
Just got back in from digging into the harnesses. Firewall fine, 02 sensor closer to the engine had a chafed wire. I used shrink tube to cover it & then put plastic tubing over it. I still hav3e rough idle, I still have sporadic rough idle. New symptom is that it will give a 26 CEL between 1600-2000 on acceleration that goes away within a minute.
If I run the motor in diag mode all is well.
Next installment. Just got back from the mechanic. waited for the truck to cool & finally did the rough idle. When it is happening the diag shows the 02's going rich/lean alternately. He thinks it is the AFM.
Any input would be appreciated as I don't want to buy a nonreturnable expensive part.
Thanks
Dunno for sure, but I'll bump you to page one.
Landtank and semlin have done a lot of work with the MAFs and VAFs and whatnot, if you don't get any hits on this, you might try a PM.....
Thanks for all the input. For this second the issue seems resolved & the final resolution (as of now) was replacing the battery ground end. I got a new one, cut off the original oem end, and the problem seems solved.
I say seems as it has seemed solved before. I found a "rebuilt" "lifetime" AFM for -100.00 which I ordered yesterday here:
http://www.directauto.com/product-e...ruiser_4_5L_4477CC_L6_rebuilt_air_flow_meter_
Part Number AFM4145
OEM Number 22250-66050
Condition Rebuilt
Warranty Length Lifetime
Current Price $99.17
What do you guys know about this company?
FWIW I checked the EPC before I ordered it says the PN for my VIN is 22250-66010 but when I look up by PN I get 22250-66050 is interchangeable.
I'll post up my results.
22250-66010 1993-1994
22250-66050 1995-1997
Edit: They are not interchangeable.
One should be an AFM (66010) the other a MAF (66050)
Oddly 22250 seems to be showing as both:
The problem still is gone just from the ground wire repair (which seemed fine) If I get a MAF I'll return it.
