Interesting guys running 38's with a roof rack are getting the same mpg i am basically stock.
I'll do you one better: my spare is on the roof
just rub it in- meanwhile my truck gets worse gas mileage than my friends Hummer 2...
hates my slow driving and it has caused its fair share of disagreements between us.here's another granny driver; out here in the southern half of western OR it's pretty easy to drive your own race, er, pace than most anywhere else tho....preliminary numbers are closer to 15 than 17, but better than 11
still working on the mileage calcs, 305/70/16's, stock otherwise, no rack, ditching the furiously fast spoiler 'cause I'll just tear it off on a low branch otherwise, if anybody wants it shoot a PM, yours for shipping.
i also get about 275 miles to the tank. my cruiser is a 93 with 310k miles (motor completely rebuilt 30k miles ago) and everything else is factory
a bit off topic, but does anyone know if the landcruisers run rich in factory tune? such as, does toyota make the landcruisers run extra rich on purpose for a certain effect (longevity of the motor, etc)?
has anyone ever put a wideband A/F meter to see what it reads at idle and at cruise ?
No idea of what it will do to MPG, I assume nothing as the truck is still pretty un-aero. I think it's a nod to keeping the dust and road spray off the back glass, but I have the wiper for that, eh?
and
as it is. Old thread, I know, but i was looking to see if 285s would fit stock when I came across this.My latest mpg came out to be 14.26 MPG corrected for 285 Cooper discovery's. It looks like the new O2 sensors are working well. I just pumped my tires up to 40psi from 35 psi so that should help also.
I might add that I am using that crap inefficient midwest ethanol midgrade blend of gas. I think I am going to start using the more expensive non-ethanol gasoline to see if that will make a difference.
Here are a few calculations I did to convince myself to quit using crappy Ethanol blend gas.
Regular gas is about 20cents more per gallon but it is a lower octane than the midgrade blend. Lets say I use the premium non ethanol gas from costco which is 30 cents more than the ethanol blend.
30 cents X20 gallons=$6 extra per tank
285miles on a 20 gal tank=14.25 MPG
Lets say I am able to get 2mpg more by using the non ethanol blend.
16.25mpgX20 gal=325 miles
Thats 40 miles more per tank or about 2.5 gallons. At $4 a gallon that would save me a total of $4. Not a lot, but at least I'm not running that ethanol carp through the engine.
If I'm able to get 3mpg more using non-ethanol gas lets say
17mpg.
17mpgX20 gal=340 miles per tank or 55 miles per tank extra or 3.24 gallonsX$4=$12.94-$6 additional for non ethanol gas =almost 7$ savings at the pump.
I doubt I'll actually be able to get 17 MPG but well see how high I can get. The problem is that I have a whole tank of the dirt ethanol crap in my tank, so it will be a while before I am able to fill it up with the good stuff.![]()
Everyone is selling themselves short. They are doing calculations as if they used all 20 gallons. The best field method I know of is to top the tank off all the way to edge of the filler neck. So it is visible. This is your reference point. Zero your trip meter. Drive it for a few days. Top it off to the same visual reference point. Divide the gallons you just put in by the the mileage. I bet most of you are getting 2 or 3 more mpgs than you think.![]()
spartan said:As long as this thread is back up and going I'll throw in my .02.
I don't think that 285's are gonna increase mileage, especially the ones on the heavy end of the spectrum. I know from experience that mileage goes down the heavier and larger the tire. Not much way around it.
It can depend on gearing, but with stock 80 gearing I believe mileage will decrease with any added weight or drag.
As for 17 MPG. I don't see how it is possible. The trucks came from the factory with a window sticker stating 12/14 for gas mileage.
I did notice that fuel mileage seemed to suffer when I leveled the vehicle with 30MM front spacers. Got rid of the nose down, but decreased what little aero' I had.
MPG on this truck stinks, but it is never on the freeway to speak of, spends a lot of time at idle and short trips. New wires, rotor, plugs, egr disabled, etc and it's pretty much a 10-11 MPG constant with the 1.06
" MULTIPLIED " correction.
Have thought about changing O2 sensors which are old, but several RKI's here on the board advised that it might be a waste of money, time and effort for little or no MPG increase.
You might get an increase in mileage with 255 / 85 tires, but not 285 /75 IMHO.
These things are just gas pigs. Just like my Ford V10. But you can buy a lot of gas when there's no monthly payment.
