MPG increase with 285s
How do you guys check fuel mileage?
Mine is speedo corrected on 285 Cooper STTs at 40 to 45 psi on the street. I use the trip meter to measure miles between fill-ups and divide the miles by the gallons each and every time. When the light comes on there is still 5 gallons in the tank based on how much it can hold when filled. The gauge is not accurate; it's on E long before the light comes on.
I am getting 13 mpg for DD around town stuff and about 15 for road trips w/ 60 mph speeds and 13 for road trips w/ 70-75 mph speeds. Best ever is 16+.
I routinely run 300 mi between fill-ups. At 12 mpg, that would be the max on 25 gallons and I only got that low once or twice when my EGR system was not up to par. Which, incidently, is why I am so meticulous about my mileage calculations, because variations in gas mileage can be a first indicator of a problem.
well i do not have the speedo correction so i am not exactly sure of the mileage. But i can say that i get around 210 miles on 20 gallons before i figure in the speedo correction. So 11mpg before correction... Maybe im not too far off at 12-13 mpg. Although i do drive on the interstate 70% of the time...
Example:
Speedo is not corrected.
Assume stock size tires are 31" tall.
Assume tires on truck are 33" tall.
33/31 = 1.06
Miles on odometer uncorrected say 300.
300 x 1.06 = 318
Fuel used = 20 gallons
318miles/20gal = 15.9mpg
With my 37s I've been getting anywhere from 220-250 miles per tank ...
X2. Most times the light comes on at ~220. Mine is 37's, ~30 psi, close to stock weight, no rack, lift sets at ~5" over stock, stock gears, "uncorrected" for anything. If I fuel it close to the light coming on it takes ~20 gal. The light may not be that accurate, may come on with more/less fuel remaining, rig to rig?
38s with 4:88s plus roof rack and every other accessory available under the Sun = 12 mpg
I have an 97LX 450 totally stock. Im getting 17mpg. I just went on a road trip 850k through a mountain pass and back. Fuel was alright but I am now down a close to a litre of oil...??.. How are your beasts on oil?/ Is this the begining of the end? 213 k klms on it.
M
if the odo is telling you you went farther than you did, then it's divide in the equation, not multiply...
285s are 6% larger than stock. It's multiply.
UA, I run the same tires you have on an unladen 80 and I found the handling got better and it feels like the truck is working less with about 44 lbs in them. YMMV of course but you might like it too.
Right. It's 6% over, your odo is telling you you went 6% farther than you did, so it's divide.
Example:
300 x 1.06 = 318
there is no way one can travel 318 miles with an optimistic odo.
Try again.
The 285s have a larger circumference than the stock tires. They therefore turn fewer revs per mile than the stock tires. Indicated mileage is therefore lower than actual. Therefore, you multiply by 1.06 to obtain actual miles traveled.
its multiply. 33's are 1.06X bigger than 31's. so you calculate 1.06X whatever miles you get/tank. i get about 305 corrected miles/tank. never filled up past approx 19.5 gallons. = approx 15.88 mpg. im on 315's with stock gears, lift, sliders & front arb. tires @ 40psi...but my emissions are shot. only running 1 (probably shot) cat, and bad front 02's. should get better mileage once i replace the 02's and cats.
you can also use the formula to calculate what gears will put you back to stock.
(34.5/31)X4.10= 4.56 gears will get me back to stock ;)
divide or multiply?
283?
283 / 20 = 14
You fail this course. Buy yourself a GPS and calculate your mileage with that.
ill get my psi this afternoon on the MTR's... But even if they are a bit low I doubt it would cut my fuel mileage by 5 mpg. Interesting guys running 38's with a roof rack are getting the same mpg i am basically stock.
I run 295/75 BFG KOs. When I have been in areas with ethenal in the fuel, like virginia, my MPG has dropped to around 10. All other areas I stay in the 14-15 range. Could be crazy, but it is what it is.
I find similar changes in mpg with 100% gasoline vs. blended fuel. I was in New Mexico this spring and averaged over 15-16 mpg on the road. We had to make an emergency parts run from Farmington to ABQ and at 75mph I was over 16mpg running the lowest grade fuel.
Back in the Midwest I the best I've gotten is 14.25mpg driving 70mph tops on the interstate, and this is after a full tune-up of plugs,wires, cap, rotor, and air filter. I am also running mid-grade (90 octane) fuel. The best I've got with regular (87 octane) is 13.7mpg.
My highway mileage at 65-70 went from about 11 average to 14-15 average after going from about 30 to 45 on my 285 MTRs and removing the roof rack. The roof rack was very lower profile, but I think still had some affect on the mileage.
I was pretty shocked myself, but I'm convinced that 30 psi on a 285 MTR puts a lot of drag on the vehicle. We'll see if my mileage remains consistent, as this was only after weekend trip of about 600 miles.
I've noticed that according to my scangauge speed plays a HUGE roll in mileage. If I stay closer to 55-60, mileage goes way up, but it's almost impossible to maintain those speeds on the interstate and not get run over.
