MPG increase with 285s
Alabama
I bought some 285s a couple of weeks ago due to unfortunate circumstances. However, I have experienced a full 1.5 mpg increase over stock size tires. I now get at least 17 mpg when I hold the speed to 65 mph or less. These tires should pay for themselves within the next 4.73 years. ;)
Keep in mind your speedo will be off (which will throw off your calculations) due to the difference in size between your 275's and 285's.
dream crusher.....
:flipoff2:
Yep. It means that you have actually traveled more miles than your odometer reads which means that your gas mileage is even better.
Smartypants.
i dont see how you guys get the mpg figures- my truck is on 285s but otherwise stock. i do 70% hwy driving at around 60mph and get about 210 miles to a tank pretty consistently. Add the mileage diff. of about 15-20 miles from my speedo being off and that comes to about 220-30 miles or 12-13 mpg (when my light comes on i hold around 20 gallons)...
i would kill for the 17mpg some of you claim.
Gisham, something else is deffinately going on with your rig. I went through a few tanks this weekend with some light off road use and my lowest tank was 14mpg. Overall about 15.5 and I wasnt babying it or anything.
210 miles per tank seems pretty low or do you fill your tank when it gets down to a quarter tank. I can usually at least get around 275 miles to a full tank before the gas light comes on and that was when I had a bad O2 sensor. I should be getting more than that now that I have replaced both O2 sensors, but I haven't driven enough to tell yet. BTW my rig is at stock height with 285 mud terrains.
'93(275,000+mi,orig) with 285 ,2.50" lift arb, sror slider , kay-mar , roof rack, 12/14mpg:steer:
Air up your tires to max psi. In the case of the 285, if it's an MTR, that means 45-60 psi. It will truly make a difference. Not having a roof rack also helps.
I think that the 285 effectively makes the diff gearing higher, which lowers the engine rpms and increases mileage. This isn't always the case in all engines, like my old 22RE powered truck, which got worse mileage with taller tires and better mileage with very, very lower gearing...but I think the 1FZ has enough low end torque that it likes the lower rpm on the freeway and runs more effeciently.
??? im with grisham, I only get about 210 off a tank (till the E mark)most city driving so that is around 11.2 MPG, so that sucks something must not be right ive checked pretty everything and im about to switch to synthetic oil, should that help much? so yeah if I got 17 I would be estatic
the truck has always gotten those numbers. i have changed all the emissions stuff(EGR, MOD, VSV, Lines) and recently popped my HG so a valve/spring job was done as well. No Difference, it gets the exact same mileage as it always did. I run Goodyear MTR's 285's and pressure is correct. Other than that the truck is completely stock. It runs great, just gets 12 mpg... If you guys think something is wrong and have some ideas of what might cause this poor mileage by all means share them :)
Oh and i should mention a tune-up (plugs, wires, cap, rotor) has also been done on the truck without any noticable mileage results.
My truck also only has 95,000 miles on it and no aftermarket bumpers or anything to add weight. Your mileage will probably be lower if you have 200,000+ miles on the truck.
MPG
With my 37s I've been getting anywhere from 220-250 miles per tank and after the correction I think I'm getting around 15 mpg mixed city/highway, and many of those miles were pulling a small trailer. I havent had it long enough to figure straight highway but it should be around 17 mpg, until i get 4.88s and downsize to 35s.
55mph and a couple psi higher than recommended in the tires and I'm getting consistent 16-18 hwy. This truck was made to drive at 55. Did the black hills of S. Dakota to minneapolis at that speed. Turned a 10hr drive into a 10:45hr drive. Averaged 16.5ish with a RTT and gas cans on the rack. Theses are correct numbers for tire size and double checking against gps.
My truck is stock except Nitto AT 305's and new exhaust. I have always gotten about 280-290 miles out of a full tank. Just went on a 600 mile round trip to the mountains ran the AC most of the time and averaged about 15.5 mpg.
I run 295/75 BFG KOs. When I have been in areas with ethenal in the fuel, like virginia, my MPG has dropped to around 10. All other areas I stay in the 14-15 range. Could be crazy, but it is what it is.
My tires have 36psi in them, fwiw.
Is that what they ask for on the sidewall? Sounds more like a passenger tire air pressure to me. I keep my 285's around 45 PSI, but really should be running them at or near to 60 psi.
