Moving to Alaska... What should I do to my Cruiser
I guess if we all had money to buy three or four sets of tires for each rig and every circumstance, life would be good, but realistically not many guys do that. The OP is only running 2.5" for lift, so I highly doubt he wants to run any 18" wide tires. Chains on AT's DO work off road quite well for short stints. I'm not saying they are the "be all and end all" solution, but they work and I've never worn a set out yet. Mine are certainly showing wear after 5 years, but not worn out.
TK
Well I drive 99% of the time on road. I have the most street friendly tires on my cruiser right now so I am looking at a good all terrain. I think I may be over thinking this but I want to be prepared.
As i said... the most aggressive tire you can put up with. Part of that is what sort of tire life and fuel economy you can accept... chains just can not match a 18 inch wide bogger. You can say they "clean" better... but they also grab less and tire size is an extremely important factor too. And when you are running hundreds of trail miles every outing... chains wear fast too.
As I am sure you have found out... in Alaska... and "All Terrain" is a "Street Terrain".
If the rig is used mainly on the road (be honest with yourself) then put road tires on it.
Mark...
This is absolutely true. In fact if you have the space (which I doubt you will) I recommend purchasing tires or even extra tires down where you are at before driving up. Terrible prices up here on such things (well evrything to be honest).
I farted around with state of the art mud terrain all cross traction super quiet yada yada tires until I tried a set of boggers. Nothing comes close except an Irok for the Ice/snow wheeling or actual AG tires.
If I had the means, a good studded tire for the winter months (nearly 7-8 months long here) an all terain for summer and a set of boggers for when I want to play.
But who really has three sets of tires sitting aorund? :meh:
Just found this thread and want to say good luck to you.
I have one battery heater if you want to come get it.
Ill take that batt heater, thanks.
Not running from the law just crappy job opportunities, and a horrible political climate. It should be a fun adventure if nothing else.
Has anyone installed heated mirrors on their Cruiser? I have done a search and came up empty.
What is the best form of communication up there, cb, ham, other?
Thanks
As an EMT you might be able to get work on the slope. i lived in Alaska 5 years and loved every minute of it. I dream of moving back some day.
Turn it into a woman. I hear there aren't so many up there.
we have a saying up here in the north.........
The girls say..." The odds are good but the goods are odd"
The guys say...." You dont lose your girl, you just lose your turn"
Good luck and get a block heater if you stay the winter!
We are starting to get ready. I am looking for some 33x10.5 A/T tires and will be installing a block heater with a factory water pump in a few weeks. I am also looking for a trailer to take up there.
We have a friend who lives up there and runs Kingdom Air ( Kingdom Air Corps ) and we will probably be staying with them this summer and getting my wife all caught up on her pilot certificates. We are getting real excited.
hummm, doesn't a block heater do the same when it is circulating the heat?
i might be missing something here since i have not bothered to study the flow system but the hot water from the block will open the thermostate and the hot water heads into the rad and down to the bottom and back into the block ... no?
i am not dishing on the block heaters, they have been in use for decades and funtion well. i have moved to the lower rad hose heater and have been quite happy with them. this is more for expanded understanding on my part.
Pretty sure block heaters don't actually heat the coolant enough to open the thermostat but I've been wrong before as my wife is so fond of reminding me.
I've been thinking of installing a block heater in my 60. The winters in Colorado don't get near as cold as AK's but they get cold enough. Is there any advantage to running more than one block heater?
So I have found it here before but after 45 min of searching I will have to ask. What is the size of block heater I am looking for? I am ready to buy one and cant find the right size. And I have heard that they make them in 400w - 600w. I would like the 600w if anybody can point me towards the right one.
I am also in the market for 6 33x10.50 BFG AT.
Thanks
Jacob
How did the move go?
I moved up back in 2002. I soon realized that an array of expensive mods to a four wheel drive can oftentimes be a waste of money due to our limited road system. Snow machines, boats, and bush flights will get you off the beaten path. There honestly isn't much wheeling to be done up here, unless you want to rev the piss out of your motor out in the muck, destroy the country side, or pack your drive train full of glacial silt that will eventually destroy your ujoints, birfields, tie rod ends, and axle bearings.
In the winter, positive traction lockers are downright scary. Limited slips are a phenomenal addition to any four wheel drive. Likewise, your vehicle must pull boats, snowmachines, supplies from town (if you live in the bush), and heavy loads of moose meat on return trips. Studded tires are also a great thing to have.
With the distance traveled, I frequently run to eagle, whitehorse, and McCarthy. The gravel can be sharp, and cooper discoverer st's WON'T suffer punctures. Likewise, tire pressure should NEVER be lowered like the offroad magazines tell you to do. Every single time I've seen a puncture on long distance trips....it was the side walls squatting to the sharp gravel because some dude read somewhere he'll get more "traction" if he lowers his PSI.
When I was in the Army up here for 8 years, I watched guys come home from deployments, and blow all their hard earned dollars on worthless upgrades, and never truly see the real Alaska. My preferred tire size to get you and your expedition equipment from point A to point B is a 265/75/R16, they're usually E-rated. If you want to keep the cruiser rims, a 33x10.50 would be a good addition. Toyo makes a 33x10.50 which arouses me every time I think of the perfect landcruiser tire for stock landcruiser rims! In the winter, you don't want to be running around on fat baloon tires. They're worthless, and spread the weight out too much. Skinny tires put fourth more traction to the ground. TALL/SKINNY. No wider than 10.50.....seriously. We aren't california rock crawlers up here......so don't introduce that expensive disease to your cruiser. Think of your cruiser as a long range hauler/tower.
Dual batteries are also important. When we snowmachine back from remote icefishing trips, a vehicle HAS to start at 40 below with no assistance from block/battery heaters. It's a lot to ask....but ask you must. 0W-30 or 5W30 in the winter months. Full length roof racks, or at least four cargo bars, you don't want moose meat/salmon coolers in your cab the whole ride home.
Dielectric grease on EVERY electrical connection you can find, it rained almost every day this past summer. If an FJ-62, pull the rubber plug where the wires run from the fuel tank, and into the rear driver side fender. The electrical connector gets real corroded, so clean it up. You may even find burnt plastic on the connector due to bad corrosion that collects back there.
Remove your seat covers, and replace the old foam, distances traveled are insanely long. It takes me 18 hours to get to Eagle to put in on the Yukon River for summer-long river trips. It takes me 20 hours to mcCarthy, usually helping people replace punctured tires. It takes a full 24 hours to Whitehorse to visit friends, or purchase canoes.
NGK irridium spark plugs, or V-powers. Gap em slightly wider than stock specs. When motors start at 40-50 below without the help of block heaters, lot of unburned fuel can make the motor dye, and get the plugs wet.
Towing revisions: trans cooler. You can also drop your valve body and have a reputable trans shop spice it up a bit with new springs or better than stock springs, since that's all a 1,400 dollar "high-po" valve body really is.
Highlift jacks are dangerous/worthless additions. A high-height cylinder jack with extra 1" thick plywood blocks are much safer. I cut plywood blocks around 16"x16" and stack them under the seats.
CHAINS Regardless of studded tires, sometimes yah just need some chains. Whether it's to help recover someone's vehicle, or get back on the road after a spill into the deep snow. After thaw periods with heavy winds.......I wish I could tell you what it's like to have the wind BLOW you off a lubricated ice skating rink of a road............my brand new studded tires we helpless to keep me on the road. The ice was too soft and wet, the wind was too strong.
Alaska Landcruiser:
Safely travel an unsalted ice scating rink of a road system
Through a blizzard, pulling a four place trailer with gobs of traction. With caribou from a winter hunt, building materials for a remote cabin, or fish from an ice fishing trip. Maybe loaded with folks for a back country ski/snowboard/or snowshoeing trip
Summer/fall Landcruiser:
Pulling ATV's, or boats that take you off the limited road system. Hauling hundreds of lbs of caribou meat, bear, salmon coolers, or moose meat. Be prepared for washed out roads, especially heading to places like Eagle.
Be happy with 55-60 mph on the highway, that's all you need, it's the speed limit. Even a 4-speed will do fine .
End of Rant.
Alaska Landcruiser:
End of Rant.
All I can say is...wow.
I guess me and my guys live a different Alaska reality that you do.
Glad we do. Ours is a lot better than yours it seems. ;-)
Mark...
No worries, and no offense intended. Everybody is entitled to recreate as they choose. If my vision of a 60/62 is different than yours, than so be it.
In regards to my reality, aint much too it, the liquid trail leads to prosperous grounds. Othewise n that....sure do like seeing a classic cruiser waiting for me on the return. No swamper boggers needed, I'm not part of any "click".
Had a good hunting season this year. The boy got his first caribou, and I shot a nice 55" bull moose.
Itching for the liquid trail to open back up, so we can pick few baskets full of fiddleheads and start the spring bear hunt.
no offense taken...not much anyway... Your insinuation that anyone who spends time off the roads here is somehow abusing their rig and or the environment IS personally offense.
And some of the things you put out as fact in your post seem to be nonsense.
Nowhere to go off road?
Skinny tires to"reach the bottom"?
24 hours to reach Whitehorse?
Those are just the ones that made me laugh loudest.
As I said, your seem to live in a different Alaska than I do.
Mark...
1. Never said there was no where to go off road, but this certainly aint as diverse as a state like Utah.
2. Skinny tires for slick snow-choked roads......yes.
3. 24 hours to reach whitehorse, yes. I take my time, the roads are rutted/damaged on the canada side. A quick roadside nap is always in order, not to mention the wildlife and scenery pictures along the way.
This november, gotta lot to ask of the landcruiser, need to haul our building materials for our remote property. The two winter pics are near it.
The other picture is about 160 water miles down the Yukon, and up a class lll river, hangin out with some Alaskans who raised four kids out in the bush. They didn't think I'd make it up their crazy river.:)
Deleted
