- Thread starter
- #41
elmariachi said:What's under the flap, a standard 110V socket?
Three prong 110v AC outlet. The cover is spring-hinged and weather sealed with a rubber gasket.
97 FZJ80 said:Three prong 110v AC outlet. The cover is a weather seal with a rubber gasket.
elmariachi said:Are you going to install this with an inverter? If so please provide pics and details, I am interested.
97 FZJ80 said:I won't be installing the invertor as I am still deciding (and waiting on funds) on the dual battery/isolator setup. The invertor will be located inside the quarter panel on the passenger side (where is LC subwoofer is located) and this AC outlet will be mounted on the inside plastic quarter panel, next to the 12V outlet.
Have you installed the cargo area lamp yet? I'd like to see the writeup and pictures if available. Thanks.
John
97 FZJ80 said:Three prong 110v AC outlet. The cover is spring-hinged and weather sealed with a rubber gasket.
Hey JunkJunk said:will post pics. regarding the wiring, you may not know this, but I already have several runs of heavy welding wire run to the rear of the truck. Some goes to the winch, I also have a remote rear jump start terminal back there, aux fuse blocks etc. Will let you know. Bracket is already built and mounted inside. Now it's just a matter of mounting the inverter to the bracket and run the wires.
No time now though..... I gotta wheel![]()
loquito said:\
Those were some great plug ins you guys came up with, but I to want to mount my inverter where the sub woofer used to be (94 land cruiser, 1500 watt inverter from costco) is it possible with such a long cable run?
Riley said:Junk - please take a few pics of the install if you don't mind. Actually the 80s moderator is doing a FAQ thing and this might qualify.![]()
I'd be interested in:
- how the inverter is mounted.
- the 12 volt wire routing
- where you located the 110V outlet ect...
97 FZJ80 said:I think Junk mentioned before that he has a 1.1kW unit in his 80. I am currently using a 70 watt all-in-one unit to power the laptops and battery charger. I noticed with the Optima battery, the battery tray has a lot of empty space left. I am contemplating mounting a high power inverter (1kW+) in there to power a small microwave oven. Has anyone try putting an inverter in the engine bay? Does it have to be a weather-resistant inverter such as the Vector Marine model? Has anyone mounted a high power inverter inside of their 80?
John
Believe so. tacos (at least some I have seen) had an outlet in the truck bed.Can that Tacoma outlet be installed on the outside? That would be nice mounted in the passenger side, rear quarter panel, under my ladder. It looks and sounds like it's built for outdoor mounting. That way I could leave Windows and doors closed, and locked.
Mine (amp) has been in there for years. No harm. That area is prone however to leaking. Check seals, blah, blah, blah.Nothing for nothing...I mounted a powered sub in the passenger side rear quarter and moisture for in and destroyed the amp circuitry...something to consider
