More Whats it
Adventure Teq
Liberty Utah
Website
www.instagram.com
So got around to cleaning up the engine bay. Got a few questions, what is that thing in that blurry pic I took? Any idea what those white plastic blocks are and where to get more of it. And I don't think that booster is OEM, does it look like it's from a 60 or something?
The guy I bought it from said that the brake system had some special fluid in it that I have never heard of (can't remember, but organic, or something comes to mind). Basically what other types of fluid you guys heard of for brakes?
Booster looks fine to me...05/75-08/79 had that style....
White poly material....McmasterCarr...they have just about everything.
http://www.mcmaster.com/
First item is an secondary odometer....emmissions stuff IIRC...should be able to remove the cable ends that have been cut off....and the cover should come off, and you will see the mileage it was at when the cable broke :)
:beer:
The white blocks are to space the aluminum radiator up.Can`t tell you what the booster is out of.You do have a Summit proportioning valve in there.
The firewall widget is the speed counter. After a certain number of miles had clicked past, it told the computer when to turn on the annoying "Check EGR System" warning light for PM purposes. You can remove and discard, seeing as how the speedo cable is no longer connected to it.
The radiator blocks are plastic. Yeah, white plastic.
Brake booster looks like FJ40 to my casual observation.
Brake fluid is brake fluid. I recommend running cheap, regular DOT3 fluid and changing it frequently because if a cruiser is getting used for its proper usage, it's gonna need the fluid changed frequently. No reason to be dumping ATE Super Blue synthetic fluid in a drain pan once or twice a year.
;) Thanks man... That pro valve seems cool, I guess you can change how much pressure goes to the back brakes manually, right?
I was wondering if you guys recognized it as anything a local store might have. Like a cutting board or something similar. I'd like to get some more for a few other areas.
I'll check out that McMaster site, thanks fellas.
Brake booster's 77 or so "big" double booster unit from FJ40. Use dot 3 fluid, dot 4 is not compatible.
john0089 said:
WoW that hidden odometer is great! I cracked it open and found out my cruisers actual milage. I have been wondering what that thing was forever! Thanks!
Don't be fooled by the milage counter on the inside of the speed sensor. It may not translate to actual miles. It is designed to go up to 50K miles then trip the EGR light on the dash. There is a switch inside the counter that resets the milage once the EGR has been serviced. There is a little round plug on the top of the unit that allows you to access this reset switch. So, if the odometer has ever been reset, you start back at zero again.
BTW - This unit also acts as the speed sending unit for the emissions control computer. It tells the vacuum switching valve when to open and close. If you still have all of the original emissions crud(ie: Kalifornia), you will need this gizmo!
For the plastic, look for "Delrin" trade name for glass filled acetal polymer.
Or UHMWPE (ultra high molecular weight polyethelyne) less heat resistant I think.
Mcmaster should have both.
WRONG. The only difference between DOT 3 & 4 is 4 has a higher boiling point. They are compatable. I think you are thinking about DOT 5 or 5.1 or someting which I undrstand to be silicone-based and not compatable.
Aha, that's it, I was going to type silicone but forgot. Yeah that's what he said it has, so I guess since look a little low I can just pick this DOT 5 stuff up at autozone. Thanks for holding my hand guys, I prolly coulda called em. They prolly wouldn't know the difference anyway though.
They may mix, or not, but I know if you put dot 3 in my Jaguar XKE, you're looking at a 3000 dollar brake job...they're dot 4 ONLY!
Dot 5 is silicon.
Dot 5.1 is 'normal' just has a higher again boiling point than DOT 4. Also more water tolerant.
Don't run synthetic - no pint, you'll never get the brakes that hot, and it's easier on the trail to run what everyone else does :)
