Your going to spend more for one of those than if you just replaced the deck with a middle of the road unit. Plus you could get features like sat. radio and ipod etc. The stock unit is just out of date. Replace it and bypass the factory amp and you will be good.
X2. Dump the factory unit, get an aftermarket head unit with a little power (Get something that puts out about '50 watts per channel') and bypass all of the stock wiring. You can leave it in place in case you ever want to return it to stock to sell it.
Drop-offs (or not the increase that one would expect) in bass response when changing from stock to aftermarket speakers can be explained as this: Those paper-cone, small magnet stock speakers are probably 2 to 3 times more
efficient than better quality after market units.
Efficiency means nothing more than the volume (decibels) produced by a speaker with a constant input signal, that is measured at a set distance (decibels of output with 1W of power input measured at 1 meter distance) A lighter cone, smaller magnet speaker will
almost always produce more output (sometimes up to 2 to 3 times louder depending on the replacement speaker's characteristics) because that cone moves easier than the materials used in higher quality, higher power handling speakers (more structually rigid cone material, larger magnets and voice-coils). Basically, it takes more power to move better speakers and the stock head unit simply doesn't produce enough power to fully utilize a better speaker's qualities.
A decent, low-investment combo of a system would be:
- A 'high power' aftermarket head unit (these are not real clean or actual power, but 50W/Channel will usually satisfy)
- Quality, Mid grade (infinity, Eclipse, JL, kicker), Front door coaxial or component speakers (use the stock rear door speakers for rear-fill)
- A small sub and amp, or easier yet, a powered sub (Infinity's Bass-Link will probably give most cruiser guys all the bass they need).
Adiophiles may start throwing stones about that setup (...That sucks, I got $600 Focals running off of a Zapco amp...) , but unless you want to take the time and invest in sound deadening and quiet tires, that combo will satisfy most people.
My setup is:
Head unit: Alpine 9833- 50W channel ($350-crutchfield sale)
Front Speakers, 6.5 Infinity reference ($85 - new off of
ebay)
Stock rear speaks, faded mostly to front
Sub: Infinity Perfect 12 Dual voice coil (100 - new off
ebay)
Sub Amp: xtant 300W mono sub amp ($53 - refurb off
ebay)
It sounds good and has enough bass to fill that big cabin, without rattling other peoples windows.
