More problems
Richmond, VA
So this Sunday, I noticed a faint tap tap sound coming from the front of the 80 at low idle. I am sure it just got drowned out after that.
By this morning, it is a loud clunk when starting, braking, hitting bumps etc. Everything drives as normal..just sounds like something is very loose.
Just as to an FYI of what has been done recently...IPOR installed an old man emu suspension (the rear shock had come loose and needed to be retorqued), so I am sure it could be the same thing on the front. They are too far for me to go to just drop by and check, so I need to either tackle myself or try the stealership.
The headgasket was also redone 3 months ago, but I am not sure how this could be related.
thanks in advance for your thoughts.
Chad
The front shocks are easily accessed. The top mounts are visible from the engine bay with the hood up on the left & right sides. They should have two rubber spacers on either side of the mounting bracket. For stock (& bilstein) shocks the order of pieces starting at the shock end is metal washer->rubber donut->metal washer->shock mount (truck frame)->rubber donut->metal washer->*LOCK* nut. I do not know if OME shocks are the same in this regard.
The bottom of the shocks are easily seen behind the front wheel/brakes. The front shocks have similar mounting types top & bottom.
If you suspect the shocks, visually inspect the top & bottom mounting bolts. They should be lock nuts. If they look ok, grab the body of the shock and wiggle it side to side to see if there is any looseness at either end of the shock.
You can attempt to tighten the lock nuts your self. You'll need something to counter hold the shock while you tighten. The ends of the shock will have locations for counter holding them. Either flattened piston tip or a allen socket hole in the top of the piston.
General tightness for shocks is until the rubber donuts stick out 1 mm outside the metal spacers. With the Bilstein HD shocks you can tighten until the threads end (I assume this is the same for most shocks for our trucks).
Make sure the mounting nuts are lock nuts.
Sounds like an installation issue. You should contact IPOR and tell them the situation. If what you're experiencing is expected they should've told you after the install.
Chad
Have you tried to tighten the four control arm bolts? This has been a recurring issue on mine, usually after a day of wheeling.
I have not tried it...I will give those items a go tonight...I am getting off a little early and have a few hours of sunlight.
some will disagree with this, but i also had an issue with a few bolts and nuts coming loose after a while. I got tired of losing bolts so i started using blue loctite on all large suspension bolts. Haven't had an issue since.
Chad
All of our suspensions are torqued to spec before they leave our shop, but the manufacturer does recomend that everything be checked/retorqued after 500 miles. This is something we can take care of immediately for you. Feel free to bring it by the shop anytime, and we'll check it out for you.
the fix
The reason I put in the fact that a suspension was installed and rechecked once already was to question if it needs constant checking, not that it was done correctly or not.
It did need to be tightened again by my measurements with the torque wrench, but that is not what was making the noise.
One of the front brake calipers was completely missing one of two mounting bolts. I have no idea how or when that could have happened.
I will bring the truck by soon anyway as the new battery is constantly draining to dead in two days of non use since the dual battery system was added and there is a leak that appeared after the headgasket job. I have spent some time underneath wiping things clean and putting fresh cardboard underneath after parking it at night, and I can tell you right where it is coming from....and it is not the rear main like Cam thought.
See ya soon!
