More ignition issues....
Virginia
I have an aftermarket ignition switch installed on my 71 FJ40. Most times, I turn the key to "on"...it begins clicking softly..then I turn the key to "start" and I get a "CLUNK" like the starter is engaging but not turning. So, I lightly turn the key back to "ON" and then slowly to "START" again and the thing starts up fine.
Last night, when I turned the key to "START" it did NOTHING at all. No Clunk, no nothing. So, I lightly tightened the screw holding the wire to the ignition cylinder bolt labeled "ST" (starter?) and it fired right up. If I over tighten this particular bolt, the "CLUNK" comes back, if I undertighten it...I get nothing. It has to be perfectly tightened for the starter to engage and start the truck.
WTF? Any ideas.....?
I went through three of these aftermarket switches and found they all behaved the same way as Herb described. Finally got fed up and got a toyota switch. Nothing like OEM.
Ahhh, good to hear that I'm not crazy...and that these "new" switches can come screwed up right out of the package.
I will order a new toyota part.....CCOT I guess.
Thanks again.
Herb
Yep, they are a minor pain in the butt....however, I can always get the truck to start...which is kinda cool if you think about it. I mean, if that happened on my wife's volvo....fuggettaboutit. I can just tinker a bit and it starts.
Thanks for the help with this...I'll follow the thread and "get to Cdan"
Herb
