more 3fe issues
Aledo tx
well my 80 series hates me. replace one thing for another to break. basically cruiser wont crank over. i had a vacuum line that looked like it was supposed to go to the charcoal canister from the air box, reconnected it and the truck died.
now when i try to start it the i can hear the fuel pump kicking on, i can hear the solenoid down by the driver side foot area turning on, and i can hear the starter solenoid clicking on and off. if i rapidly try cranking with the key it will periodically try to turn but the cranking sounds like it is seized up really weird.
fyi
starter has been replaced
all grounds cleaned
battery good
besides that one vacuum line all checks out
nuetral safety switch is in question also?
tried tapping on the starter, did nothing......
tested battery and cleaned terminals...all good
any thoughts what am i missing here, feel like this thing has had starting issues the whole time i've had it. bout ready to rip the motor out.
Starter has been replaced since this began happening? Sounds like starter contacts to me, but if you replaced this after this started happening and got the exact same results, then probably not contacts.
It’s a 91, starter was replaced last year(not a factory unit), was thinking possibly starter solenoid. Starter has lifetime warranty. I’ll try and jump it. It’s just really wierd that if I try cranking it over and over the starter try’s to engage but acts like it doesn’t have enough juice to crank......
I don’t have a battery tester or charger but may get one to see what kind of juice it holding.
Prob the coil ground. Unbolt the coil holdown cage, clean the bolts and the holes. Now run a wire from the ignitor case to a solid ground, and let us know if it solves the problem. They added a wire on the 100s to solve this.
You will prob have to rock the truck to get it off the ring gear it gets caught on, on slow turn of starter.
Since the starter was not replaced since this started happening, then I'm sticking with my starter contacts theory. You said it had a lifetime replacement, then get a new starter.
My experience isn't so great with lifetime replacement warranties. I got tired of replacing crappy "lifetime" parts. And they always tried to come up with some excuse as to why they couldn't warranty the part. YMMV. Good luck.
Recheck your vacuum lines. there are 2 smaller vacuum lines from the top of airbox to the VCV next to the charcoal canister, then a larger vacuum lines from top of CC to VCV and from VCV to back of the intake manifold.
To be clear, the coil/igniter and EFI circuits have NOTHING to do with the starter circuit. You could remove the engine ECU, the ignition coil and igniter and leave it all in your garage and it will not effect the starter circuit.
Vacuum and any emissions controls have nothing to do with the starter circuit.
I know you said you cleaned your grounds, but do you have a good ground cable from the engine block to the battery? Could it be in bad shape internally? I'd test with a jumper cable between the battery and block to rule it out.
