Mogs or Danas?
Is the volvo centred in the rear???
I did a searchon the volvos with very little luck, looking like the availability is very few.
I think I asked this question before about adapting mog portals ends to Toyota center, the feeling was the pinion would be a weak point. I though the lower range gearing in the mog ends would translate into less torque further down the axle????
Hey Orange, I guess after reading this thread you must be building a buggy to accept those portals?
the toyota centers should work, but why go that route? there's nothing wrong with mog centers, and they come with factory mechanical lockers, that can easily be modified to air actuated lockers.
yes, i've been wanting to build a buggy for a couple of years now. just was'nt sure what to run but i have it narrowed down now.
my "cruggy"concept:
shortened fj40 cab (extracab fj45) with an aluminum flatbed
tube frame
mog axles on 40" tires
some sort of injected small block
lockup th350
atlas or possibly np241, depending on how i like the gearing in a similar vehicle
i'm trying to keep this streetable for multiple reasons, although it'll mostlikely be towed to most wheeling trips.
i've tried to inform myself on axles a lot. i already had a set of 1 ton stuff and rockwells, but decided to sell them in favor of the mogs. they're way strong, factory lockers, loads of ground clearance, and fairly economical, considering what you'd have to do to other axles to make them comperable. and even if you run a 40" tire on em, you still have a lot more clearance than danas with 44s, nevermind the weight savings and stress on the axles.
Pirate4x4.com is not crutch, but rather a web site with over 20,000 members. I have yet to see a web site with the vast array of knowledge that is available there.
Ozzy version of PoR
there you go...and I find it to be a much more plesant forum where people don't flame and bash near as much plus there is next to zero sheep owners on there! And yea they know a s*** load in Aus. :cheers:
Volvo portals are both rhs drop for front and rear. I was told recently by a master mechanic who has worked on not only the volvo portals but the TGB/C-series trucks and Mogs and Pinzie's and much more...well, he said the volvo portal is a Salsbury Rover axle in it's basic design. First time I heard that one. This guy has a set of the better ratio portals for $3k. good deal and I have checked on pricing a bunch for these axles....why!? Well becuase they will go under one of my old school P-trolls pretty damn easy! $1500 each is really a good price unless they are trashed.
If possible, portal boxes on the end of dana 70`s front and rear with 40 spline axle`s. I have seen mog axle`s break and 2 1/2 ton military axle`s break just as easy as any dana 60. If you are running under 400hp, then I would stick with 35 spilne 60 70 the tera TRD60r housing. The only part of the dana 60 that my friend break`s, is the outer 30 spilne stub shaft. He is running a heavy international scout with dana 60`s and 42`s, and he has wheeled every hard trail in Colorado and moab. He has never broke his 35 spline rear axle`s.
I seen one on the Penrose trail`s here in Colorado last year, if I had pic`s, I would post them but I didn`t take any, because I had no camera. And used mog diff`s are not that easy to find. The full width one`s are way to big for alot of trail`s.
Rob,
Mogs.
These will one day be under my truck. I thought I was close to getting them but Metal Tech needed a fork lift so my mogs now are a propane powered 3000lbs lift truck. A state owned 406 just sold on line for $3K, almost complete just missing engine parts. The 406 mogs have disks OEM, nice. From what I understand the 406's are a bit lighter as well.
BTW: Did you get my voice mail about the 2nd owner FJ45LV?
Mark
orangefj45 said:
who's talking new prices here?!
and i'd love to see a pic of a broken mog axle shaft. i've never seen one!
Gorge,
Never heard of a Mog inner axel braking. I have seen a number of outer portal box housings blown. Makes since, due to them having the full 2x torque.
Mark
orangefj45 said:
that's pretty much what i've seen. broken portal boxes due to the gears breaking, but no busted shafts.
1.5 ton axles (at least on the 404)... yummmm... Almost sold my 80 for an old 404, but couldn't handle 55 on the highway and wheeling without leather and A/C... ;-)
IT seems to me that there is a lot of misinformation in this thread and a lot of people acting like they are 8 years old with the name calling and such. I believe that the premise of this thread was simple. Should someone use a mog axle instead of a Dana 60 or 70 type axle? In order to answer the question or help the person decide information or points should be presented that mean something, supported by facts or ideas. Bullshiat and name calling dont help anyone build a rig or make a decision...I know that some of it is in fun, but if you want to do that crap go to PBB, they are full of it....
Now, someone asked about using a Toyota center section with mog outers. This has been done and is a good idea for several reasons. The toyota center sections can be had with a 3.54 RP, which is the same as the stock mog center. Because this RP is numerically low its much stronger than a regeared axle, like a 5.29 or 5.88. RP and other parts can also be cryo treated for additional durability and strength very cheaply. Now that many more aftermarket toy parts are available such as stronger inners and birfs, this center section is just about bulletproof. It also eliminates the need to do a pinion conversion on the mog axle and gains some driveline length as the toy pinion is shorter. The portal ends have been broken on 404 series, i have seen pics and one in person in a comp buggy. Never seen a 416 axle broken anywhere, but you have to run 20" wheels and the axles are heavier and more $$$. Maybe a HD toy birf, like longfields, etc could be used somehow in a mog end for added strength. dont know of anyone making aftermarket mog birfields yet. You also reduce, by using a portal, stresses and loads on individual parts, where in a dana type axle, adding strength usually means adding weight to an already heavy axle. Mogs are not light for sure, disc brakes will shave a good bit of weight though. Custom Dana 60s or similar can be 5k each with some nice quality parts. of course you can build cheaper with stock parts, but then you lose some strength as well, just like in a toy axle...dont think you would need to put huge money in a mog axle to make it suit your needs...
just my two euros worth
that's some good info but it's also one sided.
i doubt you'd be able to build a hybrid toy/mog axle for much less than a dana, and it would weigh about the same. the other option you did'nt discuss which has been done and is pretty popular is the "mog 9". by using a ford 9" center you can run ring and pinion ratios as low as 2.54:1 which ends up being an extremely strong gear set. only probelm with the hybrid axles is the added expense of custom axle housings and custom shafts (mostly 300m), so they get pretty pricey. running hybrids does allow you to play with the gear ratios, locker options and axle widths quite a bit. they also end up weighing less than a stock housing and 3rd member.
another real benefit to running portals that's vastly overshadowed by their huge benefit of the extra ground clearance is the fact that the portal gear reduction relieves the amount of stress put on all the components before it (axle shafts, ring/pinion/ u-joints, drive shafts, t-case,......) by roughly 50%. thus allowing you to run smaller, lighter components without having to sacrifice strength or durability.
one more benefit is the shallower pinion angle and therefor driveline angle. this makes for a longer driveshaft and u-joint service life and since they're up higher, they're less prone to smack a rock and get damaged.
i did a lot of research before deciding on which axles to use for my "cruggy" project and the mogs seemed the most sensible choice. can't get more "bang for your buck" then by going with mogs.
just my $.02 worth.
orangefj45 said:
and you'd have to change the t-case no matter which axles you go with.
Not true...the Cruiser case works fine with Volvo portals.
I think the obvious first question in this debate is what you are doing with the truck and what size tires you want to run??
Obviously, I am biased toward the Volvo's...but I do always carry a little concern over the strength that would be mostly gone with mogs. IMO...if you build light and drive reasonably Volvos are good for up to 42's. Mogs....much larger. So...depending on what you plan to do, how much clearance you really need for that, and what size tires you are planning to run.
The Volvo axles are more available than most guys know. There are already a few guys importing them and I know of one guy that will get them to the nearest port for around 3500. There are a few difficulties with them...but the clearance rules!!
Lastly...keep cracking on IFS and you may be suprised one day. Charles...I am betting that Walkers IFS rig would spank YOU anyday. We can't let pro rockcrawling make our final decision for what will work on our rigs.
It kind of depends on what parts you need. Its kind of like the whole perception with finding parts for Cruisers. There are quite a few aftermarket parts available(axles, birfs, lockers) and quite a few interchange parts (seals, bearings) and quite a few part that you just don't need to replace (housings, r&p, etc).
Yea, let's compare Walker Evan's $$$$ rig with my junk. No doubt that it will spank almost any non-competition rig. I didn't build my rig to compete so I don't think that it is a fair comparision. I'll bet if I were to spend 50 to 100K building a competition rig without
IFS, it would do quite well with Walker Evans.
We can't let pro rockcrawling make our final decisions, but we can all learn from their
R&D.
R&D.
Well, we can certainly learn from what we see in pro competitions, but I have no intention of letting that be the gospel. If I did..my dog would be walking, my girlfriend would be carrying the cooler, and I'd have a 3000lb winch bolted in my crotch.
Charles....if you can make your entire argument ablut IFS by saying "IFS SUX" without even mentioning the topics of "forced articulation" or "angle of operation", then I have to agree that you just don't understand IFS.
I'm sure there was a time when someone was pointing and laughing when the first guy bolted a set of 31's on a Cruiser instead of a J***. Anyway...enough with the Hijack of this thread...I'm sure there's plenty of room for all of us on the trail.....just not in the competitions.
