Modify/Re-Code AHC height setpoints?
San Francisco
Hi guys! I can't find anything on google or the forum so figured i'd reach out here to the real experts :)
I'm about 1.0" shy of fitting into my garage in low mode and looking for a way to tune/modify the set points of ACH heights. I do realize that I can adjust the sensors to effectively lower the normal and low settings, but I'd like to maintain the as-driven (normal) ride height at the slight 'sensor-lift' height I have it at now.
There are two ways i think (operative word - think) to achieve this:
Option 1. Do a "reverse sensor lift" to where 'low' is basically dumped, 'normal' is some variation of low, and 'hight' is where i currently am at. I'd get the high mode override
Option 2. Somehow code/modify the actual set points to my heart's desire. I like this the best so i can retain the normal and high mode heights.
any ideas?
Thanks in advance!
- J
I do not think it is possible to change only the L mode, without affecting N. Also when on L it is already pretty much on bump stops. Have you considered removing the roof rack, if not using it?
I'm not aware of a way to modify each setting.
Also, ACH is for your checking account. AHC is the suspension on your car. Active Height Control. :)
I like the idea of removing the rack. I also park with limited height available.
good point I'll check how much room is left before it engages the bumps
oops hahah - yes AHC (also i just bought a couple keys from you - coordinated on Instagram on colors hah. Feels like a rifle when i go to start the truck every time, very solid 'cachunk')
yeah I'll have to, unfortunately it's the roof *rails* that i'd have to remove and not just a box or rack :/ we use them about 2-3x/month to haul stuff so it'd be a bit of a hassle.
Looks like modifying the sensor heights is the only way at the moment (maybe I can get it low enough where H is the old N height). Actually, does modifying the sensor lever arms change the H height? or just N and L?
All heights are based on the sensors. Any adjustment of the sensors moves all heights.
Is Low all the way down regardless of where the sensor(s) are positioned?
Not quite. Low (in factory height settings) is near, but not on, the bumpstops.
  • Like
Reactions: GTV
