Missing something on Window Up Mod??
Southeastern Virginia
Greetings. 1995 FZJ80. I've carefully disassembled and cleaned my power window module while waiting for the Window Up Mod diode from WitsEnd. After letting the parts sit for two days fully disassembled, I suddenly notice the apparent random appearance of a small spring! I don't think it's part of the switch assembly, as I don't recall removing it, but I can't explain where it came from. Crazy.
Looking for verification that this spring is NOT part of this assembly:
If it is, please let me know where it belongs.
I'm wondering if one of my kids has played a practical joke...
Thanks much.
Thanks very much to @tlin's earlier post quoted below. Apologies for not searching deeper. Thought I had it covered. Appreciate the help.
Spring attaches to back side of window lock (plunger style) switch (the small square pictured on the right above in Taco's post). It faces the white nylon portion of that switch, the shorter arm sits at 9:00, same horizontal line as the hole of the spring which goes over the small stem, and the longer arm rests within the channels of the nylon body accommodating the open/closed or up/down feature of this switch.
To reset properly:
1 - pry plastic square button top off the nylon stalk of the window lock/plunger switch. It's not glued or press fit, it comes off pretty easy.
2 - now the white nylon stalk, the black plastic housing assembly and "torsion spring"......nylon stalk stays inside black plastic housing, spring rests on back side where you can see the small black stem the hole of the spring slides over. Do the small arm first then carefully guide lower/longer spring arm's "foot" into the white nylon guide channels with your fingernails (big hands/paws make this part hard).
3 - carefully slide completed assembly into square opening pictured above on the left. You will need to carefully squeeze the front in so that the assembly will slide down into that square. Once you get that in, do NOT ever again pull that out just leave it in that seated position.
4 - once done cleaning carbon off metal contacts, replace springs on white stalks (5), and all silver rockers. Marry two halves back together and once screws are back in you can then replace square window lock top again (only goes on one way).
Clear as Mud? I should shoot a video of this since I've done it a few times and have it nailed down. Can do this weekend if you don't get resolved based on my Watson & Crick writeup here. Good luck!!!
With the small torsion spring mystery solved thanks to @tlin, I'm now trying to find out why I only have two of the supposed five small springs that slide over white nylon posts on the switch assembly (as mentioned in earlier & related threads). The two I have are pictured below.
@tlin mentioned that these shouldn't have any bearing on the mechanical function of the switches, although I believe the two I do have in the photo above must transmit power to the light bulb in the driver's side auto switch.
Thoughts on whether the other white nylon posts should have springs or not? I may see if I can find suitable replacements at my hardware store.
God help me when I decide to tackle the oil pump cover gasket, as I've been so obsessive with this simple window up mod...
just five springs, they do fit on little white posts that provide grounding to the switches. If you look on the top piece (dark brown in my case) you can see the five copper squares where the springs contact the top.
Got it all back together, and I'm happy to say that the windows work.... better. Still a far cry from perfect. Looking at maybe replacing the rubber... also pulling the doors off and making sure that the motors are grounded well and that that there isn't too much voltage drop between the + and the ground.
If your switches are balky- this is a pretty easy mod to do... just do it with good light, clean surface, and try to limit the potential for springs and e-clips flying too far!
If you're anal retentive, you'll be back in there soon enough to fix the window lock switch. Hopefully my experiences last year with that little headache resulted in some sort of writeup you'll benefit from and shorten your repair. That's the goal of Mud....
"White rocket"? Doesn't ring a bell (for some reason my mind wandered to Vegas.....kidding). Please post a pic of it, that would be helpful.
I never knew exactly what the function or necessity of the five little springs are, they certainly don't impact the electrical or mechanical aspect of the window switches so no sleep loss if a few are AWOL. You're now the guinea pig, if you figure out what goes wrong when they aren't all there, do share!! :)
Welcome to insanity - miser loves company? :)
In your first pic, there are three naked nylon stalks without springs - that's where the missing three springs would normally be located (sorry for stating the obvious). No need to theorize why they aren't there - they simply aren't there. Is it a problem? Doubtful......the bigger headache is the plunger switch spring which you've already resolved. If it were possible, I'd teleport every single guy (for some reason, I can't imagine any gals have been in this situation) who've wrestled with that little bastard-of-a-spring for a beer to do a quick cheers but.....life doesn't always work the way I want it to so this will have to do.....:beer:
Btw, if you are doing or considering LC Phil's constant power window mod then now is the time to remove the little light in the switch to prevent it from draining the battery long term.
And sorry you're having issues :(
Thanks guys. Appreciate the offer of the beer! I actually had one while getting that torsion spring back in and it helped!
Everything went back together just fine. I commented in @landtank's original Auto Up Mod thread that I managed to install the diode on the component side of the board without removing the PCB from the assembly using @NLXTACY's diode. Again, as with the spring, patience was required.
Everything went back together great. It's a neat little mod!
Regarding those three "missing" springs, I'm not even sure the were there in the first place. I was so careful taking it all apart. The torsion spring on the window lock popped out by itself the next day - glad I found it!
By the way, CRC's Sensitive Electronics Cleaner really worked wonders to clean all the fouling on my contacts.
Easy mod. Nice to have.
