Missing outer snap ring on Birfeild
Atlanta Ga
I just got the truck a few months ago. i just installed ome stock height suspension and bigger tires 295/75/16. I no noticed a slight rubbing / grinding noise when tuning sharp right going 15-25mph. Noise won't happen all the time. It's intermentent when turning. After a few days now I see al leak at the dust cap on the right front hub. I removed the dust cap and found the snap ring at the end of the axle is missing. Could this be what's causing the noise and leak? Allowing the axle to move to far in when turning. Are three any other problems that this could cause. I have the snap ring ordered. And will be installing it as soon as possible. Thanks for any help and advice.
A member @toadshade had the same thing happen to him after a rebuild about 2 weeks ago. Take off the cone washers, remove the cover and inside you will find two large nuts that hold the entire assembly in. Between these nuts is the thin metal piece that you fold over the nuts to lock them into place. That piece was not folded over the nut all the way causing some movement. Tighten everything to spec and you should be good to go.
Yes, the missing snap ring may be causing the noise. Replace and see if that fixes it. Thread a spare bolt into the end of the shaft so you can pull it out far enough to get the snap ring on.
