missing on cylinder 6
read through those other posts....going outside with a razorblade now to expose all them stinkin wires...roll of 'lectric tape on hand to verify any temporary repairs :D
Do not, I repeat, DO NOT use that razor on yourself out of sheer frustration :D
I forgot to ask, your coolant level in the overflow tank isn't going down, is it? Maybe make a mark and watch it for a week to really determine that. Also, can you repeat the #6 miss if you power brake the engine? This procedure rotates the engine a little bit, forcing the harness to move.
misses al the time. I cannot make any promises as to sef mutilation at this point though.
colant level is steady, just happens to be one of those things I pay attention too:D
I forget how I did this but instead of self mutilation I had chosen to call Dan and get a new harness :D; my injector was (and still is) fine. Anyway, I think you can unplug the #6 connector, hook up a volt meter leds to the + and - pin of the #6 connector, turn on the ignition and see what volt you get. I forget what you should see with the ignition turned off.
what a fawking pain! the tape is completely gooified, and I cannot get enough slack to get a meaningful look in there.
I had to walk away... tomorrow I will pull the upper intake to get to the whole harness, I moved the hell out of the bundle, while it was running, with it disconnected completely from the firewall. I got all excited when the RPMs came up, but it turns out I was pushing the throttle assembly with the palm of my hand.
I am about a hair's breadth away from parting it out and being done with it
You must have faith my son......hang in there and take a breather. We'll help you through this and learn a thing or two in the process. Go have some :beer:
had the same problem a month ago, with #6 was missing.
went through all the steps.
after a week of trying everything, it turned out the distributer cap was leaking electricity!
My #6 was missing also. No external block evidence of coolant leak, but I did a reservoir bubble test, and it was positive. Turned out the #6 ring was the problem.
Hope that's not your problem, but since you're already pulling the upper half of the intake, might as well replace the HG. If it hasn't been done, it's gonna eventually go.
Amazingly a new engine harness is not unreasonably expensive, which was actually a shock to me.....
The words that give many shivers.....:crybaby:
back at it again....
completely exposed the wiring harness, no breaks or wear on the wires (traced them out)
compression check is good
#6 inj. OHM'd out @ 13.8
it soudns like it is shooting, but I could be hearing the other injectors (screwdriver to ear test)
Essentially, I have done everything possible to avoid removing the intake, while trying to think logically in the face of sheer frustration. I did remove the hood, which made it a bazillion times easier to get to everything.
Tomorrow the intake comes off, gonna replace the valve cover gasket as well as it is leaking a bit. I figured I would just fix it, then decide on wether or not I want to keep it :D
One more thing you can try and that is check power on Voltage test and power off Continuity test at the ECU connector. This is a central place from where you can access every single electrical device. Accessing the ECU is very easy, directly behind the glove box. You'll need to unplug the mondo connector and use the DVM probes for testing.
The FSM has a very detailed step by step chart to help you isolate a particular component.
In my 1996 Toyota FSM, the pages that are of interest to you are:
EG-220,221 Standard Value of ECM Terminals
If you don't have the FSM, I can scan it for you or someone may have an electronic copy of the FSM already.
I'd at least try this approach before going through the trouble of removing the intake in the hopes of finding something.
Good luck.
ok, it is the injector...I am 99% sure at this point.
my buddy runs a shop, and brough over something he called a Noid. It is essentially a LED with 2 leads on it. You plug it into the injector lead, turn on the motor, and it will blink as it fires. Steady blinking in time with the engine, demonstrating that the signal is making it all the way to the injector. I wish I had this weeks ago :D
New injector is on order, and there is a chance I will have it back up and running by Christmas!
Yea, Noids are cool!
i can't recall, didn't you check all the injector resistance value already? if your #6 injector is bad, then after a brief run, that spark plug should smell different than the rest. Did you see this?
I had the same problem - # 6 not firing causing low idle, tremedous engine shaking at certain RPM, lean engine code. I replaced plugs - to no effect. I had a set in another 1FZFE engine, so I had those injectors cleaned and flow checked at a local EFI shop. Then pulled upper intake and pulled injectors & opened up the wiring harness. Couldn't find any issues with the wiring so wrapped with heat-reflective tape from Checker and put the clean injectors in. Replaced plug wires because I broke one of the distributor-side plastic locks.
Runs great now adn purrs like a kitten at idle. Better than it has in the last 40K miles. Starts instantly, not after 1 or 2 engine revolutions as before. Probably 10% more power than it had prior to #6 failing.
It took a good 2 days to pull apart, test and put back together, but well worth it.
Good luck with yours.
We have seen the #6 injector fail a few other times. It might be due to the higher heat back by the EGR valve. We've also seen bad connectors on the injector that made it look like the injector was failing.... again, at the rear of the engine.
-B-
Yup, checked the resistance, but didn't smell the plug, but I can picture me burning the crap out of my nose while trying to take a whiff:lol:
-B-
still waiting on the injector, should be in today. Hope to teardown tomorrow!
We should have a betting pool - #6 injector or something else!!
Pulled the same code this past weekend. However, mine was due to some water I forded. Evidentally, I got the dizzy a little wet. The LX sputtered pretty bad for a few minutes. I drove the next day and all was well.
I will lay a golden twinkie if it is something else:lol:
I have everything here now, new gaskets, injector, injector rings, etc. I have her in the carport (still) but there is a leak in the roof directly over the intake:rolleyes: The rain has sorta stopped, so I may go out there and get started...or not
