Missing igniter for ignition. Options?
TX
Hi Everyone.
My cruiser runs horribly and I've been chasing issues for years. I replaced the distributor and carb with @Trollhole products. I still can not get it to run correctly. As I've been pouring over forum posts, and wiring diagrams, I realized I'm missing the "igniter" that sits on top of the ignition coil. (Who knew a 40+ year old vehicle would be missing parts?!)
I'm going to ask what might be a very stupid question.
How necessary is the igniter?
What are my options, as you can't run to NAPA and pick up a new one?
Thanks in advance.
What year?
Hi Everyone.
Thanks in advance.
trollhole-wiring-diagram-only-77-oem-coil-jpg.1039579
Thanks @GA Architect . That's how it's currently wired. The spark appears to be pretty weak. I was hoping I had missed something.
Post up some pics of your set up. I'm sure some of the more knowledgeable members will be able to help.
If I go back to the original distributor, I'm assuming I'll need the igniter, correct?
Does anyone know what the igniter does?
When you say it runs bad what does it do? Smoke, sputter, bad idle? It could be a lot of things. The set up you have is the same as mine and I have the ignitor bypassed like @GA Architect posted. Works great. All you need for the dizzy is 12v and ground.
I would start at the basics. Adjust valves, plugs, wires, vac lines, fuel filter, timing, idle mixture, etc. Make sure the basics are in order.
It is not unusual for a Thole carb to have some debris in it that plugs up the idle circuit and makes it run bad. A quick clean out will usually resolve it.
It is an ignition system component that is responsible for providing the signal for the ignition coils to fire, so that the spark can be produced for cylinder combustion to occur.
If I switch back to the original distributor, will the engine run without the Ignitor? I understand it works with the distributor, to signal the coil when to send increased voltage. I’m assuming the dizzy won’t operate properly without the coil and igniter working together. Correct?
Its a ‘73 fj40. It’s run VERY poorly since swapping the TH carb and dizzy. Recently, it has stopped running at all. I’d like to adjust valves, but need it running first.
I’ve done all the other basic fixes: new plugs, wires, fuel filter, new gas . . ..
Before it stopped completely stopped running, I set the timing, and rechecked it 10 + times, so I know it’s at least close enough to run.
I reinstalled the original dizzy. That’s when I noticed I’m missing the igniter.
So the question is, will the original points dizzy work without the igniter? If not, I need to find an igniter before I can use the original dizzy, which I want to install to see if the TH dizzy is the reason the vehicle isn’t currently. Make sense? :-)
So, it was running ok before the carb/dizzy replacement. I believe you can run the points without the ignitor and I "think" the FSM may have the procedure to bypass it for testing.
My gut feeling is that the carb may have an issue. The carb uses the idle solenoid only for idling. When you unplug it the car should die. if it continues to run then you are getting fuel from the mains and that is bad. Could be linkage, trash, hanging throttle. Easy enough to open it up and clean it. There are several threads on this. Fuel in float bowl? Initially I had issues with my carb, and actually bought a different one, but once I got it cleaned out it has been very reliable.
Why are you leaning towards ignition?
I was leaning towards ignition because the spark seems fairly weak, and I’ve installed two TH carbs. Surely they’re not both bad. They shouldn’t need to be cleaned, as they’re brand new.
The sight window shows that the bowl is half full. I’ll try unplugging the idle solenoid and see what happens.
Thanks for the ideas.
