@HSTexan He's got a point. If you choose the crusher, I'll haul it off for you.It's probably worth having a competent mech test all the EVAPs. Or just take the LC to the crusher...it's a write off![]()
How often have you forgot to switch it off? I’ve been guilty of this as well but only a couple times and only for a few minutes over 15 minutes. I now set an alarm on my phone to remind me.That does make sense and to be completely honest I'm not nearly as well versed in the evap system. I do know that at the root cause if this really is the fix, it's for sure from the LRA and from me not being careful enough. I need to be much safer about turning off the fuel transfer and keeping it low enough that if I boil gas on the trail it doesn't boil high enough to run up and out of the filler neck. And maybe just for good measure stop working the aux tank so hard
I could not get a straight answer about this, and even asked if they had a photo of all the plugs together last week when we were going doing that path, but from the sound of it from what they told me, the plugs in the 6 and 8 were the quite a bit noticeably worse (what I posted pics of) and the others were just pretty bad.Glad you seem to have got this sorted. Still a bit strange that it only misfired on one bank - probably just coincidence. I assume all 8 plugs were equally carboned up? May as well inspect or just replace the PCV now.
I've actually only forgotten to do it once; it was probably forgotten for about 10 minutes. I usually set phone alarms as well, but I happened to be streaming music that day and the alarm just muted the audio and it slipped my mind why. Big brain fart on my part. I usually only transfer when I get down to 1/4 of a tank and I only transfer half the aux tank (15-20 min timer), but that day I had definitely pushed it. I've also boiled gas 3 times, twice when the tank was full enough to leak out of the gas cap some.How often have you forgot to switch it off? I’ve been guilty of this as well but only a couple times and only for a few minutes over 15 minutes. I now set an alarm on my phone to remind me.
I hope this is the fix for your Cruiser!
I transfer at 1/4 as well and do so until the gauge jumps up, that’s anywhere from 12-15 minutes. It seems like it’s an inevitability that the canister will need replacing with the LRA. We don’t daily ours and it sits in a garage the vast majority of its life so I’m hoping there’s not a lot of EVAP stuff going on since the temps in the garage are stable. I park it full so we’re ready to go on our trips when it’s called upon. So far so good but your experience has been very educational, if it is actually the canister.I've actually only forgotten to do it once; it was probably forgotten for about 10 minutes. I usually set phone alarms as well, but I happened to be streaming music that day and the alarm just muted the audio and it slipped my mind why. Big brain fart on my part. I usually only transfer when I get down to 1/4 of a tank and I only transfer half the aux tank (15-20 min timer), but that day I had definitely pushed it. I've also boiled gas 3 times, twice when the tank was full enough to leak out of the gas cap some.
Why are yall kicking the man when he is down?@HSTexan He's got a point. If you choose the crusher, I'll haul it off for you.
No idea--and it's a valid concern and one that still makes me feel slightly uneasy as well. I think it's less that they're the only two and more they ended up being the worst of all the bad. From the information I've been given, none of the plugs looked good or at least normal, those two and cylinder 2 just happened to show problems first. But you're right, I don't like that the specific codes were all on the same bank.One thing to keep in mind.. due to the return-based fuel pressure control system the fuel in the primary tank will get much warmer than that in the aux..
So while there is an increased fuel volume, the portion that is emitting a lot of vapor when the conditions are correct isn’t much greater.
Though yes external factors can flood it.
I’d wonder about the evap purge VSV if liquid was going through it.
Also.. any theory why only those two plus would see the purged fuel? The nipple for vapor return is right in the middle of the manifold inlet behind the TB. I don’t have any idea how the internal plumbing of the manifold is set up but it seems strange that the fuel wouldn’t be better mixed by the time it makes it into the engine.
Ok that makes more sense.No idea--and it's a valid concern and one that still makes me feel slightly uneasy as well. I think it's less that they're the only two and more they ended up being the worst of all the bad. From the information I've been given, none of the plugs looked good or at least normal, those two and cylinder 2 just happened to show problems first. But you're right, I don't like that the specific codes were all on the same bank.
Well the charcoal canister arrived yesterday and they got at it this morning. Advisor just called me and let me know they just got the canister out and it was absolutely full of gas--to the point where when the tech disconnected it, it spilled all over his face. The running theory is that the flooded canister dumped so much vapor and potentially even excess liquid fuel back into the intake plenum where it vents which caused a super rich condition for an extended period of time and fouled the plugs early and caused the misfires issues.
My LRA has been installed since 02/24 and I've used it a ton. I probably should have been letting it sit empty periodically so the canister doesn't have to work as hard on 48gal of gas and has a chance to recover, but with how much I've been driving in the past 4-6 months it seems like every time I gassed up I was filling both tanks. I am always extra careful never to top off the tanks because I feared this, but I have definitely boiled gas before so I don't doubt fuel ran back down into the canister.
They're going to wrap up getting the new one installed, then drive it today as well as tomorrow with pick up slated for tomorrow afternoon
As a side note, does anyone know if the connection between the filler necks is above or below the line for the charcoal canister? Curious if forgetting to turn off the transfer pump and letting it fill to the point it's got to drain back into the tank is below the canister line.
I've read through that thread a number of times--it's likely time to bite the bullet on taking some preventative steps myself. The only times I boiled gas were when I had freshly topped off and had full LRA and near full main tank, in August in Texas when it was 100° outside and we had been wheeling all morning. The other was at elevation in Colorado, on Kelly Flats during LCDC when we had been stopped for awhile recovering another vehicle, then continuing to push on before stopping for a break (where I heard it). I had just filled up the previous night--though at that time I did not yet have the LRA when that one occurred now that I think about it.Glad things are at least moving along and that there was definitely a problem with EVAP system with plausible explanation for misfires.
I think there's still a root issue that's not accounted for. The EVAP being flooded might only be a symptom, and may appear again if the root cause is not addressed.
Might want to take a closer look at the fuel boiling issues. What are your mods for skids? Do you have any fuel system boiling mitigations or insulation applied?
I believe part of the reason this is cropping up for you this year might be related to the recent EPA decision/waiver as a result of the Iran situation to allow cheaper winter blends to persist through summer. Winter blends have a higher Reid Vapor Pressure (RVP) by design, to facilitate ignition in the cold of winter. That same formula in summer creates more volatility and more load on EVAP systems. Combine that with a rig that traps more heat with skids, but also has increased fuel thermal loads due to the LRA placement in proximity to the muffler, can lead to fuel boiling issues that overwhelm the EVAP and engine. It might be liquid fuel going into the purge valve for which the manifold will not flow evenly as it was designed gasses.
Addressing points others have brought up
- No, fuel fill level generally does not affect RVP. But it can affect how much heat the fuel system can sink from heat sources before increasing in temp significantly and boiling. So more fuel may allow the fuel to stay cooler longer before its heat soaked.
- IMO, the return fuel system being hot is a red herring. That's always been accounted for in the system design. It's mods that add to the heat load of the fuel system that overall creates issues.
That said, there's documented effective mods around the fuel system, tank, LRA, and even the return system that works. I no longer have fuel boiling issues (at extreme elevation).
This thread is not quite a comprehensive fix (yet), but hopefully gets the ball rolling to improve upon fuel venting/boiling in the 200-series. I don't have complete answers and hoping there will be continued contributions by the hive mind. This is one of those issues that may not have a single magic bullet fix. It's a balance of use cases and mods that exacerbate getting heat into the fuel system versus mitigations sufficient to overcome heating factors.
Synopsis of Problem
Fuel has increased volatility and vapor pressure known as Reid vapor pressure (RVP), at elevated...
- TeCKis300
- 200-series cruisers diy fuel fuel venting vehicle tech
- Forum: 200-Series Cruisers
But I'd be lying if I didn't say the unnecessary stress of that first phone call saying blown head gasket
Well it’s home—they had driven it twice today for about 30 min each time and I did a 20 min test drive before I left. Immediately following spent an hour getting home fighting rush hour traffic. It drove great, no issues—had a chance to really hammer it during the test drive and I’m sure things started warming up in the bumper to bumper. So far so good so crossing my fingers we are through with that saga. If so I can now focus my efforts on preventative measures so we don’t end up back here again. A small part of me feels a bit of relief, but another part is waiting and expecting the CEL to come on again. Will put a couple thousand miles on it over the next couple months to get some confidence back in it before CROCKIES in July.
Sorry to bird walk but what happened to that door??b
