This is worrisome as my 2021 HE is coming up on five years this May. It now has 77,000 miles on it. Please keep us updated. I am so sorry to hear this. Hope Toyota will treat you right.
I know I've looked at it before and I want to say it was 11/20 or 12/20.Wow, I’m sorry to hear this. Is this the first heritage edition 200 to be subject to this?
Oil changes are not really the issue, but rather the coolant, and they do recommend 10 year/100k in the service intervals for the first set of coolant (every 50k after that) so I don’t see the maintenance history being an issue. Especially since you had it changed at 60k.
The head gasket coating was probably defective (maybe Covid QC issues?), flaked apart after so many heat cycles, let coolant into the cylinder, and washed off the cylinder walls causing the scoring.
Do you know the build date of your cruiser?
What’s up with the cylinder wall scoring? That seems more typical of a mechanical failure and not a head gasket. And misfires on 2,6, and 8 but not 4? Did the HG let go in multiple locations? I wonder what’s going on with that head? Maybe more than the HG?Well Toyota called and it’s looking like worst case scenario. They went down their list and ended up pulling plugs and scoping the engine and while cylinder 8 looks ok they said there was a lot of scoring on the walls of cylinder 6 along with some coolant. They’re thinking head gasket issue. I’ve never overheated, never had issues with temps. They’re going to start a case with Toyota corporate for me to see if they’re willing to assist in this because while I’m over the mileage for the 5yr/60k I’m under the time as 5yrs of ownership is actually this upcoming Monday. Their initial thought is engine rebuild or engine swap. Will update me again on Monday. Absolutely gut wrenching news
Not sure yet--it didn't make it into the shop until around noon so they didn't have a ton of time to dive into it. They told me I'd get a more detailed update on Monday with their findings. As far as I know they hadn't even scoped beyond cylinders 8 and 6 at this point and called me as soon as they found a bad cylinder.What’s up with the cylinder wall scoring? That seems more typical of a mechanical failure and not a head gasket. And misfires on 2,6, and 8 but not 4? Did the HG let go in multiple locations? I wonder what’s going on with that head? Maybe more than the HG?
From some basic research and if I still go through Toyota even if corporate decides not to cover any part of it it can range wildly based on what kind of engine you replace it with. But the general sense I was picking up was $15K on the low end up to $30K using new partsWhat will something like this cost to fix outside of warranty?
Sorry bud.
For the love of God and everything holy, don’t do this with GM’s newest generation of $h*t that’s their version of the 3.4 v35a.Ls swap it
Not really - 2021 during covid, parts supply issues, and manufacturing issues. Oh, and things happen. Find me 250 2021s with a bad head gasket and then maybe we have something to discuss.This is crazy for a 2021 with 75k miles.
At least that’s much better news than the first. Fingers crossed it’s the latter.Well I just received an interesting update call from the dealership. They wanted to do a leakdown on it over the weekend so they hooked it up and pressurized it over the weekend and came in this morning to find that it was exactly where they left it 36 hours ago. So apparently the scoring on the walls is not as bad as they thought--not exactly sure, he said they didn't have pictures since it was just through the borescope, but I asked if he'd be able to try to get some for me. Either way, if it's not losing pressure the rings are holding and so is the headgasket. They also said the cylinders were bone dry, so maybe they assumed coolant, but was actually some fuel? I'm not sure how a tech mistakes the two. They did say the plug for the bad "scored" cylinder was very orange, so I'm not sure exactly what is going on.
It sounds like whoever looked at it Saturday was not the shop foreman, and this morning the shop foreman looked over the first tech's work and did not agree. They're doing new plugs all around and an EFI service and will see where it stands. At this point I'm extremely confused, slightly skeptical, and all around unsure of what to believe. I had him send me photos of the two bad plugs they pulled out. I just don't understand how you go from scoring and coolant in the cylinder to "it might only need plugs and an EFI service."
I was not and haven't ever--the only thing I do is run 87 around town here in Texas and then switch to mid-grade or premium when I hit higher elevation to make sure it's always at least 87 or higherAt least that’s much better news than the first. Fingers crossed it’s the latter.
Were you using any fuel additives? Sometimes they can leave orange deposits on the plugs.
Part of a plug analysis is looking at and comparing all plugs. I'd reserve judgment until that happensWell I just received an interesting update call from the dealership. They wanted to do a leakdown on it over the weekend so they hooked it up and pressurized it over the weekend and came in this morning to find that it was exactly where they left it 36 hours ago. So apparently the scoring on the walls is not as bad as they thought--not exactly sure, he said they didn't have pictures since it was just through the borescope, but I asked if he'd be able to try to get some for me. Either way, if it's not losing pressure the rings are holding and so is the headgasket. They also said the cylinders were bone dry, so maybe they assumed coolant, but was actually some fuel? I'm not sure how a tech mistakes the two. They did say the plug for the bad "scored" cylinder was very orange, so I'm not sure exactly what is going on.
