Mini knuckle upgrade - which torque specs?
MD
Our group is presently doing a drum to disc upgrade on a 72 '40, using mini truck outers: knuckles, spindle, and rotors off of an '85 I think. Also adding the Longfield 30 spline birf/axle pkg. We're using the sst to determine the proper shims.:cool:
My question is do we use the mini truck wheel bearing torque specs or the cruiser wheel bearing specs?? Unaccountably, they are quite different.
TIA for your help.
Different wheel bearing torques? Huh?
I don't understand your question. Wheel bearing are wheel bearings. WTF does drum or disk have to do with it or am I missing something?
From Cruiser FSM
Stock front disc cruiser wheel bearing torque specs: ~5 ft/lbs inner nut; 70 ft/lbs outer lock nut
From '85 Mini Truck FSM
Mini truck front disc wheel bearing torque specs: 18 –21 ft/lbs inner spindle nut ; 33 ft/lbs outer lock nut.
As I said, they're quite different. Which to use?
If you are SOA on this project, I'd also suggest a higher trunion preload than factory....IIRC, stock is 7lbs preload on the fishscale, "many" of us with SOA rigs run in the 10-12lb range...measured off a 90 degree pull from the steering arm PRIOR to installing the felts on the backside
Hate to say it, I never knew there was a torque spec for wheel bearings....mine get tightened down until the rotor doesn't spin freely...back off a 1/2 turn or so, and it's done.
If the spindle, bearing, and nuts are all from the mini, then use the mini's torque specs.
(Although I confess to doing it 'Woody style')
No SOA, remaining SUA, but thanks for the input. Good to know.
Sounds like we should use the mini trucks specs then.
Are you sure that the inner bearing nut is 20 FT-LBS and not INCH-LBS?
Ft-LBS sounds real tight.
I just set wheel bearings by feel like Woody.
Yes, I owned an 85 mini and still have the FSM.
