My '96 LX450's A/C began working intermittently about a week ago (it worked fantastic up until then). The clutch would only engage about 20% of the time.
My first guess was that the compressor was bad and needed to be replaced. So out came my wallet...
Had a shop properly evacuate the system, install a new compressor, and recharge.
No change. Compressor is still not engaging. At this point it basically never engages.
Since the freon has been charged by the shop and professionally balanced, I believe that I can assume the system is properly charged and is not failing to engage due to low refrigerant level.
So I began to troubleshoot it tonight as an electrical issue. Here is what I have done:
-Jump 12v straight to compressor - compressor engages when this is done
-Checked fuse
-Taken meter reading at compressor lead from harness - 0.4 volts.
-Tried bypassing low pressure switch - no change.
Here is where is gets weird. I removed the A/C fuse to check the voltage at the input and output terminals. When I started the car up with no A/C fuse, the compressor engaged. I cycled the A/C on and off a couple times as it began to function and the compressor turned on and off accordingly - blowing nice cold air each time that it engaged. After about one minute of this, it quit working and that is where I am. Bizarre.
I was distracted by its sudden "come to life" that I did not measure the voltage at the fuse terminals while it was working. When it is not working, the left terminal is 12v and the right terminal has no voltage at all.
Any ideas?
-Checked fuse
Any ideas?
