Military tires
Nelson, BC
I'm interested in upgrading to some 37's from my current 35s.
The military tires I've looked at are pretty skinny, so it could help on the fuel side of things, to keep the rolling resistance down.
But, do military tires have a max speed?
I still want to drive at highway speeds but worried these won't keep up.
Any info?
Alot of military tires are rated for 55 I know my 325/85r16 Michelin XML's were. I put over 25k on them consistently drivin over 70 all the time. He'll I went from Los Angeles to the Texas state line towing a trailer in heat then snow loaded with a full-size on the trailer coming back in 30 hours without so much as a flinch from my military tires. I was flying would of been back faster but hit 5 hours of snow LOL
The michelins and other high load type ones are rated for 55, people air them up a bit to reduce contact surface and drive them at highway speeds.
The goodyears that everyone seems to like off the humvees are rated for freeway speeds. Or at the very least, there aren't any reported issues with them and freeway speeds.
They're not really any skinnier than typical 315's. 315 mm = 12.4015748 inches. 37's are 12.5" wide.
So I wouldn't exactly call them skinny.
I also wouldn't expect them to be very fuel friendly. They're heavy, especially if mounted on the steel military H1 rims.
You'll also have no problems running them at speed on the freeway. They're rated for an insane amount of weight on vehicles that regularly do highway travel.
You will need beadlocks if you want to do any serious offroading with them
Especially if you air down alot
If we are talking about the 16.5 then yes, or you can make your own safety bead on the wheel. Many threads about this on priate.
Now the XML's i've had at 5lbs driving down the road because the compressor at the gas station near the trails was broken.
Yes I was refering to the 16.5's
Even though the price on these tires are good, in the end it costs more with beadlocks and having to weld on your own safty bead
Not worth it in my opinion
So what are the benefits to running military tires vs non?
Military tires tend to be significantly tougher than non. The civvie version of the Goodyears have 3 ply sidewalls, the military version has 4. Because they're all used (90%-95% tread), they're significantly cheaper.
If you don't mind the weight, you can purchase a set of tires and rims for far cheaper than just tires in the same size.
Most 37's are $400+ per tire. I paid $289.95 for a tire and rim, which is dual bead locked and has a rock ring. And if I break a tire, I can pick up a replacement at around $100-150, or a whole new set of four for $400-500 (as opposed to $1600+).
The thing is if they were so good more people would use them but they dont
There is a reason alot of people dont use them
Bottom line is that they are cheap but they are not that great in terms of hardcore wheeln
Wheeled with guys that had them and they are just not a great wheeln tire and they suck in any kind of mud
There are so many threads online that have nothing good to say about the military tires
Some people like them, to each their own
They are just not practical tires if all you want are 37's to heavy
You are better off finding some used 37's somewhere else for a conventional sized rim
All they are is a cheap alternative that is really it
Are the military tires that much heavier than conventional tires?
I have a set of 16" rims, so the price of some 37's are really cheap.
Well, the military uses them all over the place and has no problem. :meh:
Are they they best tire? Well, no.
But which is better, a super great tire at 15-20 PSI, or a decent tire at 3-5 PSI?
And are you really gonna complain 20-30 lbs of weight on rigs that often weigh 6k lbs plus? :lol:
Depending on how you have them setup, yeah, they're heavier. IIRC it's around 140 per tire/rim with the Hummer take offs, and a rock ring welded on. Depending on your setup you could be running 75 lbs (for a light 35" and OEM alloys) to 100 lbs (for a 37 and alloys).
Which 37's are you looking at? I didn't find anything over 35" to be cheap.
You can keep fooling yourself into thinking that these tires are ok
They suck bottom line or else more people would run them
Just because the military uses them around the world does not mean squat
99.9% of the military tires see dirt roads thats about it
To compare a good tire at 15-20 psi to a decent tire at 5 psi, what?
They just dont compare to any good 37 inch off road tire at any pressure
And yes 20-30 lbs of rotational weight is a huge difference, the weight of the truck irrelevent
Like I said all they are is a cheap alternative to a good 37 inch off road tire thats all they are
If you do any type of seroius off roading save your money and buy some real tires
Finally someone speaking the truth!
I have hated the Goodyears on my H1 since the day we bought it. Useless in snow and mud. Only thing they are good for is high mileage on a 9000lb + rig. And, I would guess they can take a bit of light fire....
Mine are about wore out, and that's the only reason they have not been replaced.
If it was a hardcore wheeler they would have been gone long ago. The truck only really gets worked pulling a trailer in and out of the bush camp on fire roads.
That's my .02$!!
Cheers
Doug
I think it depends on the military tires you're talking about. The new Goodyear Baja's seem to be quite a bit nicer than the older style.
But a lot of it depends on where you wheel too. :meh:
The Military Baja's are next to impossible to get
For desert and or light off road use they might be ok but thats about it
For the road they will last forever
I think the OP needs to really think about what he will be using his 37's for
If he just wants 37's just to have 37's then I think that the military tires would be ok but you will be stuck to a 16.5 inch tire regardless and your tire choices are limited at best
And to change to a different rim size any time down the line he would have to get a whole new set up
I used to think this, but there are actually quite a few choices in the 16.5" flavor. Less than 16" to be sure, but a surprising amount of manufacturers carry that size. Like TrXus, which one I'd seriously consider going with if I was getting a new tire. There's also the Guard Dogs from Treadwright which look nice (strong sidewalls, softer tread).
There are some choices but not alot is what I found when I was thinking of going the military tire route
I just dont think that these tires are a great choice for the normal 80 driver that just wants 37's to have 37's, because there is a risk of opening a can of worms when it comes to balancing and out of round tires etc. which is well documented, that most 80 owners will not want to deal with let alone have to deal with a 145 lb wheel/tire
The OP needs to do some more searching and reading
I would never run a retread tire on vehicle that is a daily driver and you carry family and friends in regardless of what people say its just wrong on all levels
And I will say it again,
There must be a reason more people are not running these tires even if it is such a great deal.
This is true...for flat centers. For pressed centers there are far fewer issues with balancing.
Slightly out of round tires or out of balance tires can often be dealt with by spinning them on the rim. BTDT with one of mine.
You absolutely need to get a shop that is decent at assembling these to work with them. Trail Worthy Fab isn't a tire shop, they're a fab shop. They do no balancing and don't assemble them that well. But again, that's not their job function. Most of my issues were resolved with tearing two rims apart, and putting them back together properly. I still have some vibes from the other two rims, but not significant except over 70 MPH. Those will be getting redone when I tear them apart to paint.
A lot of the folks that I've seen that have issues (and yes, I've read those threads) either are DIY or have flat centers. If you don't have a tire balancing machine, you can't tell how the weight is being distributed and can't tell how to spin the tire on the rim to reduce or eliminate it. TWF flat out says that flat centers aren't for road use.
They're heavy, no doubt about it. A lot of weight can be saved by using alloy rims, or light steel rims which aren't terribly expensive. I don't have a problem with them, and it's a DD for me. Nearest wheeling to me is over an hour away (mostly freeway). Next closest is about 7 hours either north or south. So freeway driving is a big deal breaker for me, so far no complaints about these (or at least none that I don't expect to get resolved when I get the other two tires rebuilt).
That's absolutely your choice, but all the studies done have shown that retreads are no more dangerous than new tires. Treadwright has a lot of tires out there with very little complaints about them, 99% of the feedback is positive. And a lot of the tires they sell are designed for DD, not the occasional wheeler.
Retreads are used for far more demanding applications than our light truck use, including commercial trucking and airliners. If retreads hold up just as well as new (according to studies/research done and IRL), then what's the problem?
FWIW I'm running Treadwright's BFG AT style tires on the :princess: rig. The tire shop that installed them were very impressed with them, you can barely tell they are retreads and the mounted and balanced with less weight than most new tires. And they were initially very leery about installing them.
That argument is a rather poor one. If LC's are such great vehicles, why isn't everyone running one instead of a hummer/jeep/etc? Slee shortbus bumpers must suck because they're way less popular than ARB's. :rolleyes:
Just because not everyone and their brother is running one has nothing to do with how good or poor a choice it is. And I don't think anyone's saying that these are the cats meow, there are a lot of down sides to them (like any other tire/rim choice).
I will tell you one big reason, and that's the fear of the unknown. Ordering something like this essentially blind is something that a lot of people don't care to do. I know for a fact that is why a couple people I know ordered ARB's instead of something like the Shortbus (which they admitted they liked better). People often choose the safe route, even if it's the far more expensive one, and even if they don't like the safe choice as much.
But like I said, there are plenty of down sides to these that would make someone else choose another combo, and there's nothing wrong with that. Weight, lack of flex (though when dual beadlocked that's a non-issue), not as aggressive as some would like, hard rubber.....those are all valid reasons not to choose it.
But there's lots of good reasons to chose it, and cost is only one. Very tough (4 instead of only 3 or 2 sidewall plies), about the cheapest dual beadlock setup you can get, longevity, a decent all around tire, proven in many conditions, very quiet on the road....there's more than a few good points about them.
Any tire/rim combo you choose will be a trade off. If you pick the ultimate off road tire, it ain't gonna be a good DD (too soft, too knobby, and might swell up like a balloon on the freeway).
And FWIW, TWF sells quite a few of these tires and rims. So there are a bunch of people running them, maybe just not many in your area. Even in my relatively small home town I see military 37's pop up on Craigslist fairly regularly.
