mile marker PE8000
Nashville
I know this is unofficially illegal on mud, but I am starting another thread quickly on the mile marker winches. I won a PE8000 at the local 4 wheel parts store. Do I keep it and wheel with it when I get a front bumper, or sell it and save a bit more for a warn of the same size. Cheers,
Joel
I know now why they were raffling the da** thing at the 4x4 shop! You know what they say, stuff is only worth what someone will pay for it. I would have guessed higher than a dollar...
Toss it! that is about how reliable mm winches are. Better yet use it at as a paper weight in the garage. A buddy of mine bought one because he didn't want to spring for a Waren. Long story short. It broke the first time he tried to use it. Four wheel junk wouldn't honor the warranty. He had to send it back to the MM and was told that it had been abused. Few months of waisted time, he bought a Waren.....
Joel
Get a Warn, Joel.
Just because winches have the same rating doesn't make them equal. Let's compare the Mile Marker PE8000 and the Warn M8000i:
Layer pull rating:
Don’t just look at the “max” winch rating but the 2nd and 3rd layer line pull ratings since this is where most winching is done.
You're supposed to leave about half the 1st layer wrap on the drum to provide proper holding. So, if you compare the different layer ratings the Warn has a nearly half ton pull advantage over the Mile Marker by the 2nd layer on the drum.
By the 3rd layer the Warn can pull a 1400 lb. heavier load and by layer four the M8000 has close to a full ton pulling advantage over the PE8000. The Mile Marker has a layer 5 even though both winches hold the same amount of cable, 100 ft. By the outer most layer on each winch there is a 2330 lb. pull difference.
Warn - 100 ft of cable
Layer 1 = 8000 lb.
Layer 2 = 7280 lb.
Layer 3 = 6670 lb.
Layer 4 = 6230 lb.
MileMarker - 100 ft of cable
Layer 1 = 8000 lb.
Layer 2 = 6335 lb.
Layer 3 = 5243 lb.
Layer 4 = 4473 lb.
Layer 5 = 3900 lb.
My recommendation is MINIMUM a Mile Marker 12000 or a Warn 12000 for a 80 series... I kwow that too many people use 8000 or 9500 but I think if you really need a winch at any moment 12.000 lbs will be good!
sold today for $250 on craigslist. Will now save some coin for front bumper/winch. Sorry about the $1 bid, dudes, it wasn't enough...
cheers:beer:
