I work for a company that has about 6 of these in play, and while the winch itself has been ok, the remote (newer, 5 pin) is a piece of junk. We have probably averaged 3 pulls per winch before the wired remote needs to be replaced, the switch is very light duty and the contacts carbon up immediatly.
I have a Ramsay Pro Plus from my 40 that also has problems, but they seem to be with the grounding of the motor only. I have had to do a couple of modifications to the winch ground (mounted it directly to the motor housing) to make it reliable. I currently have the Pro Plus mounted on the 80 and carry a snatch block for those times when more power is needed.
There is an 8274 on the work bench in the process of being rebuilt to put on the 40
Just remember, the biggest winch in the world is completely useless if your attachment points won't hold
