Metal in front diff
I've done searches and find some conflicting info on this. Some say only fine flaky particles are OK, others say small chunks are acceptable and a manufacturing byproduct. I couldn't find pics for comparison. Anyway here's my pic:
For reference, the coin is 19mm / 3/4" diameter. This is the first time I've changed my diff oil. I don't know if it's ever been done before but I wouldn't be surprised if it never has. Car has almost 160,000mi on it.
Mostly the pieces were randomly shaped but at least one (didn't notice any others but I can check) was an obvious corner (like a broken piece off a tooth). Lots of them were chunky shaped, i.e. not flat flakes at all. They _might_ be e.g. machining swarf from manufacturing that I read about in other posts, but the corner piece isn't.
There is no suspicious noise from the diff nor any other symptoms of damage. Another forum says I should remove the carrier for inspection/repair. The state of the diff oil says I need to overhaul the front end anyway. I wanted a second opinion from you guys since this seems to come up occasionally and some of you seem to know what's up on this issue.
I was thinking I'll put a few more miles on it and when I get around to doing the front end I'll drop the oil and inspect the plug and if there are any more pieces then pull the diff otherwise leave it and keep it in mind next time I change oil.
I had this in my Jeep front Dana 35 diff several years ago.
I have yet to change my 80's dif fluid as the PO had a Toyota dealership service the F & R diffs 10,000 miles ago.
In my jeep, shavings & pieces like those pictured were all on the magnetic drain plug. I drained fluid, removed diff cover and sprayed brake cleaner in there and wiped everything up, cleanted the magnet real good too. It apparently was from the break in period because I have driven it tons and changed the fluid several times with no more metal or problems.
I hope this helps.
Yeah, all that came off the plug. I had replaced the oil before reading that I should've cleaned out the diff first, seems a few people did that. Whoops. I'll do it when I do the front end.
Normal machining grundge. Every 80 front diff I've changed the first couple times had some and I once brought a little bag of these to show the LandCruiser Chief Engineer when he was in the US. Normal. Not neccessary to 'clean' the front diff housing, either.
DougM
