roncruiser said:
Hi,
I saw a post of yours concerning the replacement of the O-ring. I thought to PM you as not to hijack the thread.
I need to replace the O-ring as well. You mention turning the motor to move the rotor to an easily referable position. What exactly do you mean by that? Only because I don't know
. Is that before removing the distributor cap, or after?
Did you have to make any adjustments after everything was buttoned up or was everything good to go right off?
Thanks for your help, and hope to hear from you soon.
Ron
the distributor is gear driven off the intake cam, it is important that they be reassembled in the correct time. how it came apart is how it should go back together.
to achieve this you will mark the distributor base where the bolt is with marker or paint pen or similar, and then remove the distributor cap and make a mark on the distributor where the rotor is pointing, use a straight edge or alike to get a accurate mark, if the rotor is pointing down then it might be difficult to work with so put a socket on the crank and turn the engine, as you turn the engine the rotor will also move, one revolution for every two revolutions of the crank. turn it until it is in a spot that you will have a good reference for example the electrical plug, pointing to #1 cylinder etc, straight up and down using a level, what ever you choose as a reference, does not matter exactly where it is just as long as it goes back in whatever spot it was in when you took it apart.
after you remove the distributor do not turn the engine or the relationship will be lost.
after you reinstall the distributor with your rotor pointing the right way and the distributor aligned to your mark near the bolt, put the cap back on, and re set the timing, you will need a timing light. if your distributor bolt making was accurate then you will not have change it much, but you will need to check it to be sure.
The FSM has better detail and the drawings will be helpful
also shows witch pins to short when setting the timing.
if you do not ave the FSM you can download it for $10 from Toyota, see the "fully automatic FSM download" thread
Hope that helps
Raven
