- Thread starter
- #101
I repeated the other side over the weekend and installed the new tie-rod ends and did a half-ass tape measure alignment. Took it for a test drive and no more death wobble with the new wheels and tires on. Drivers rear still has a wobble to it (i think the shaft is bent or the bearing is out) but this rear will be getting swapped for the fj60 one i have.
I did have to install some spacers up front for the wheels to clear the calipers. I would have had to do that anyways to match the width of the 60 rear once its installed. In the pic below i also have some spacers on the rear to get an idea of what it will look like.
New water pump and thermostat went in over the weekend as well. During the drive, it didnt completely overheat. I still think its not running cool enough though. Hoses were real hard with pressure and the radiator was very hot to the touch. Plus i now have a leak that i didnt have previously. I think its the radiator as im pretty sure i broke the drain plug trying to drain out some of the coolant for the water pump swap. Time to order a new one. Im thinking a cheap ebay aluminum one for now.
