Maybe problem? Maybe
Sounds like your cdl actuator is jammed. Trying driving in circles on GRAVEL or DIRT and see what happens. My old 80 used to act up sometimes when I would try to engage/disengage the actuator. It would eventually work.
If I remember correctly the actuator has a ball in there somewhere that sticks. If it doesn’t work you might remove the actuator and cycle the actuator on and off while electrically connected but mechanically disconnected from the truck.
No sound coming from Relay or actuator
I took it out and checked it with an multimeter i can pull it out again and put some vice gripes to holed it closed and check to see if the light comes on.
If it is jammed, adjusting all your tire pressures to equal will also help.
When you pulled it and tested what did you find?
When compressed I had continuity
