I put that heat shrink on there just to protect it a little more.I did do that I think one end goes to the fuse box in the engine and I doint remember the other end where that one goes. I will have to double check. I was reading a thread by CruiserOrlando (Another 150A alternator and wiring upgrade) and that is the same two wires that are shown so I will unwrap the wiring harness and trace the wires.
Yes sir I have done that but I think I might of messed up on the wiring. If I have that correct now I can go from there,I have another trans relay on the way was only like $30 bucks.The FSM has inspection procedures for just about everything. If you need help finding something, give a shout.
As far as helping decipher the EWD, try to break the systems down in your mind, so that you don't have to wade through all the wiring at once. If you think the problem is the relay, concentrate there first. After that you will be able to confirm your suspicion, or not. If you don't find the problem there, you have to move on from there.
There are flowcharts for troubleshooting too.
