...but when you brake to a stop, and then accelerate again, do you feel a very slight "thud"? The best way I can describe it as if a gear is resting on one side of a cog and when that cog starts spinning again it hits the other side of the gear's tooth. Happens every time I stop and accelerate again. If I stop quickly or slowly, doesn't matter. If I just release the brake it happens, but not as hard as if I were to use the accelerator RIGHT after braking.
This could just be the auto tranny doing it's thing, but I'd like to know if it's worth having the dealership look into further. I could just have started noticing it and it was always present, but to me it seems like a new thing occuring.
Also, my GPS has never obtained a satillate signal, it only works based off the vehicle signal sensors (which actually do quite a good job keeping you on the correct road, except when traveling on the highway straight for long distances as well as going offroad. The tech removed the headunit (I was there) and pulled all the plugs, but nothing was disconnected or loose. We buttoned it all back up together and drove it around and it went back into "3D Hybrid" mode! But a few days later stopped working again. Any ideas?
I'm pretty sure the GPS is the 2-conductor blue harness by itself on the rear of the headunit. Right now when I enter service mode, the GPS reports a status of "NG".
Thanks!
Thanks!
