Marlin steering upgrade
MH, IDaho
Well since my wife and son are out of town I'm tackling a long list of Cruiser projects this week.
Last night I installed this Marlin Heavy Duty relay rod. Great product, great folks to work with, and a reasonable price. Make sure to call to talk to them when ordering this to make sure to get the right one. There was some miscommunication on steering terminology and I received the wrong one. It is quite a bit bigger than the old one, and it is straight and doesn't have press markes on it from being straightened a few times. It also has Marlin's greasable tie rod ends which seem to be nice.
First, I want to chat a little about removal. My friend owns an automotive repair show and he told me that I shouldn't use a tie rod seperator to remove the rod ends. His technique is just to pry lightly on the rod while hitting the steering rod end with an air hammer. This method is quite effective and you don't tear up the rod boots. Since I just had it off a few weeks ago to straighten it I didn't hardly have to buzz it at all. I'm using a cheap Harbor Freight air hammer. It doesn't have any power at all but it works for this. I think this is the only thing it has ever worked for.
I always find this a good time to check over my knuckle studs too. So I retorqued them.
Next, I ground my control arms more in anticipation for more rubbing. I have the Slee Caster plates with J springs and 1" FZJFilmore sparcers. I wish I would have removed the rod like this when I initially installed the caster plates. It would have saved me a lot of time.
I moved in the rod ends 35 turns on both sides and this seemed to be about right with the old rod. It wouldn't matter if it was 100% or not because the old rod was tweaked. Then I did a home alignment to see how close I was. It turned out I was within an 1/8".
About the home alignment. Basically you lift each front wheel barely off the ground and scribe the tire. Then you measure at the centerline of the tire front and rear to see if the measurements match. If you can't do centerline you have to use the same measurement height both front and rear (in my case I used some wood blocks to ensure that I was measuring at the same height front and rear. Then you adjust the rod until the front and rear match. My friend's dad (74) with the shop taught me this. They used this method in the military for big trucks in the Korean War. He told me that if I was careful with my measurements I should be able to get it as close as a machine. His big reason for teaching me about this was should I need to do a trail repair to get home.
Tomorrow I'm going to take it down and put it on the machine and see how close I got. It drives straight so I'm guessing I'm close.
Yup I’ve been running the Marlin .250” DOM tie rod and relay rod for almost 2 years now and they been bulletproof., very happy with them.
I bent the stock stuff on two separate trips a couple of months apart when I first got my 80. The stock tie rod was the 1st to go while crawling some boulders… bent to the point where there was only a hair of clearance with the driveshaft. Stock relay rod bent when I was snow wheeling crawling down/up a really steep bank…kind of surprised it bent where it did. nose dive down cross a frozen creek than immediately up…lot of force with the snow deep as it was I quess but I was only running 33's.
Brian
Hey Eric, that's too funny that you just did that upgrade too. It was more of a pain in the arse than I thought (just the disassembly). But I am pretty sure the new rods are bullet proof. And the guys at Marlin are awesome! Best customer service I've ever recieved from any mail order vendor in my life. I will buy from them in the future anytime.
My only problem with Marlin has been the lack of parts availability for 80s. I wish they would do something for transfer case gears. In a perfect world I'd like a 1:1 high range and 3.X:1 low range gearset. I don't think it is possible though or I think it would be done.
I run their stainless brake lines and now this steering rod. I'll upgrade to the other steering rod if I bend the front one.
I'm always impressed with his generousity to Land Cruiser events. He gives a lot and really he isn't even a LC specific vendor, it is just something he dabbles in.
Fit is fine. Everything went really well. I bet the whole job only took an hour and 15 minutes with the home alignment. I was off 1.2 degrees. Knowing how to get the rod off with the air hammer I think made all the difference in the world. My joints had 220k on them and they are still great. Unless you get a hole in a boot or they are bad I wouldn't replace them just on mileage.
I have always measured from tire to tire front and rear at the same height and the "same" lug. I like your way as it is much more accurate. Thanks for sharing.
You mentioned that the the front and rear should be the same. I understood that the front should be 1/8" - 1/4" closer than the rear or toe in. Did your measurements today change where you initially put the toe at? My tires only have 2k miles on them and I don't want to over wear them by having my toe too far in.
I'll have to check the measurements again to see what they are after the adjustment. This might take a few days. I'm neck deep in projects.
Yeah I agree, I told them the same thing when I spoke to Steve the other day.
I did both rods at the same time since I didnt want to chance bending the front one like I did the rear (it was so messed up!)
I've always heard (from alignment guys) 1/8"-1/4" toe-in, and that's what I've always done, with no excessive tire wear. Try to get it at 0 and the natural slop in the parts will allow the tires to toe out and the truck will want to wander. Ask your alignment shop what they recommend.
-Spike
Well, that settles it then. I like reliable info.
-Spike
I never thought to check my FSM. :doh: Problem solved.
