Marlin Crawler sliders?
Bainbridge Island
I saw that Marlin Crawler has a set of 80 series sliders for mid $450. Has anyone here tried a set? I have been looking for a set of sliders yet cannot swallow the almost $800 that everone wants for thiers. I need ones that stick out enough to be used as a step as wide as or close to as wide as the oem running boards. I have looked and all I have seen is the Slee and Hanna ones the the DIY georges. Got the wire feed yet no torch, just a chop saw. Should I use up my next to last favor with the wife and buy a set?
You know they are uncoated and weld on for that price right? I'm not saying it is a bad price just that you need to compare apples to apples. Mine are sort of a running board slider It is made from rectugular tubing with the lower corner cut off and a piece of plate welded in. I like that I can stand on them without having to balance on a tube. I would think if you got a torch you could fab up something similar since you already have the welder. Think of what tools you could buy for the price of the slider and what other projects you could use the tools for. However, if you time is valuable screw it and just bite the bullet and order some.
rainy day,
I bought a set from Marlin and will be delivered on Tuesday. I search for sliders, bolt on vs weld, high cost and low cost. I also looked at fab shops to build a set. I didnt want to spend $800 for sliders with the other stuff I want/need for the cruiser so I went with Marlins. I looked at DOM steel to make my own and its not cheap. Time was an issue with too. After reading their forums/BBS,etc it appears they know what their doing and been around for 10 years.
If you need more step I am sure Chris Geiger at Marlin can accomodate with what you want.
Good luck.
Yes, our bars do not come painted. I think powder coating rock sliders is a waist of money because it comes right off in the rocks just like paint does. I use spray paint on my bumpers and rock sliders so it's easy to touch up.
Our rock bars are a weld on design, but the only part that weld on is the feet. After it's welded on it can be unbolted at any time. The DOM we use to make our bars is much more dent resistant than similar sized electric welded tubing.
Chris, can you post a pic of the passenger side and how your sliders deal w/ the cat placement? Specifically for a '94(side by side) if you don't mind. I wasn't aware that you guys offered sliders, and I agree about the powdercoat vs. paint issue. I also don't mind welding to the frame and can do it myself, so it seems these would be ideal for me. One question, are the side tubes angled up or can they be made level to the ground(to serve more as a step)? Thanks
Ary
I would not put the outer bar level. The bend are there to get more stiffness. Just like pickup bed if the floor are just flat sheet of metal you could imagine how thick it would need to be to be to give the same stiffness. The 0.120" wall DOM are enough if you put it at an angle. If you weld the outter bar level you will end up with a lot flimsier bar.
The bars angle up about 10 degrees, right after the legs.
The front bar that goes under the cat is removable. In the future we plan offer a skid plate for the cat that works with the bars.
Cool
Is Andy building those? That guy can work some serious metal... :D
Looks like a great product!
Chris, what do you think of selling me a set w/ the bars not angled up? I had .120 wall 2x4 sliders on my Heep and never had any problems. My 80 is not a hardcore wheeler, just a weekend warrior, so I'm not too concerned w/ the .120 wall being too flimsy. I was thinking I could skin the tops of the tubes w/ some 12 or 14 guage sheetmetal to make them look like normal steps.
Thanks for posting the pics. I think I know where I'll be getting my sliders ;)
Ary
Yes, Andy Widner is fabbing steel for us full time!
We would be happy to make them flat, no problem.
Chris do you still make sliders for the 80 series? I need a set for my 91 with the cats on the drivers side.
