Mark's 4WD Digital Speedometer Conversion Unit questions
Cincinnati, OH
I am thinking about buying the non-universal unit, Part: SOF1307 1991-97 Land Cruiser / LX450.
Slee - Speedometer Correction
If I install this will the odometer read correctly as well?
Also, is there an existing hole anywhere where that this can feed through so I don't have to drill a new hole.
Thanks in advance.
Yes, they both read correctly upon calibration. I didn't find another hole to use but it was easy enough to punch a hole in the transmission tunnel under the center console. I put a little paint on the raw metal and the box sits under the drivers seat.
I have this module. The odometer will work correctly. The only thing that is not correct on the website of SLEE, I think, is 91-97.
91-92 had mechanical trannys and mechanical speedos. At least here in Europe. So no correction of speedo or shifting points if you have a 91 or 92. I changed my tranny to a 93 one, along with my speedo. Now the tranny shifts back when it should on my 35's and my speedo is correct.
Does it adjust for gear ratio change as well?
Hmm, I don't know. English is not my mother language so gear ratio change... I dunno :)
The only thing I know is that the tranny normally shifts at certain speeds and amount of throttle. The speed sensor is connected to the tranny and the TPS sensor (throttle position sensor) as well.
By putting on bigger tyres, your speedometer will be wrong and the tranny shifts at wrong (actual) speeds. For example: Your overdrive will come much later or will never come depending on the road :)
I drive 120km/h at 2200RPM. With 35's and speedo correction.
My engine doesn't have any trouble getting the 35's to that speed, but I do have a 1-HDT :)
Maybe I'm the one not understanding this. I understood it to say that you input original tire size, then your new tire size, and it auto adjusts for the different diameter. I have done speedo corrections on other vehicles that I have owned and the control box had settings to enter the tire size, as well as the gear ratio (in case you had re-geared) so the final out put is pretty exact. To the OP, sorry, I did not mean to hijack your thread.
I would assume that since this plugs in-line to the VSS, that would take into account all other gearing.
Yes, it corrects for gear changes and tire sizes. I don't remember drilling a hole, I think I might have found an existing hole and used it but am not 100% sure.
I have the kit from Slee. It allows you to program for tire size and make further manual adjustments...cant recall if it gives gear options because I have not re geared. On my 96 there is a plugged hole just underneath the passenger side dash if you peel the carpet back.
Thanks... the unit size looks pretty big. I was hoping to hide it away somewhere
Are you looking at his CB radio or the converter box?
You got it. Mine is tucked further forward and stuck to the evaporator case with double sided emblem tape.
If i didnt have the radio there I would not have mounted it there. I cant recall if there was much extra wire length left but the glove box would be a good spot.
