Hello all,
I am somewhat new to the forum (first post but been parroosing for a while). I have an issue that has come up and need some advice and/or opinions!
So the automatic transmission in my 1990 HDJ81 has decided to bite the bullet so to speak. The truck has about 245k kms on it.
So instead of rebuilding it I am leaning towards doing a manual transmission swap into the truck. Mostly because I prefer manual transmissions and I suspect that it will be more reliable (arguable I know), better fuel mileage and better for towing.
The truck has the 1HD-T engine (JDM import), so the logical choice would be the H151. However I like what I have read about the H55F as compared to the H151 (shifting, gear ratios, etc). From what I have read on here is that it is possible to put the H55F in the 80 using a 1HZ bellhousing and putting a "modified" shifter in it (plus other odds and ends of course). The other motivation for the H55F is that I have easy access to one...
My main question is this... Is the H55F strong enough for the 1HD-T, keeping in mind that I will be towing with it too (no more the 2500 lbs).
I hope I'm not asking a question that has been discussed to death already (sorry if I am) I haven't found a precise answer to that question though.
Thanks!
Alan
Thanks!
Alan
