Manifold stud/ bracket ID help F engine
Goforth
Austin tx
Hey gang, have a’68 with the original F engine. Intake manifold has a leak and causing loss of vacuum. At the rear of the engine there’s a stud with a bracket. I was looking to replace this stud since it looks like a life of pipe wrenching has worn the edges and the nut is cross threaded. I couldn’t find this part in the FSM. Wondering if any of you all can help me id it. Looking to replace the stud only and it appears longer than any others.
Thanks. Photos below:
That is not stock. That is why it is not in any manual. Manifold is probably not flat and someone tried to hack a fix to try and force a seal.
@65swb45 another post for the wall thread
MWAG is the 1 piece exhaust manifold is cracked and this was a bad fix. look at the alignment between the intake and exhaust manifold at the bolt.
you will need to remove the entire manifold assembly and see what the real issue/problem is.
YeeHaa, we got us a winner! Agree 100% with @3_puppies ...unless you're the one who came up with the clamp. In that case, :hillbilly: to you Charles!
Seriously, you're going to have to take the manifold off.
Interestingly enough, someone called last week to ask about adding a hole in the front. I wasn't afraid to share with them the story how over 30 years ago I was frustrated with a header that wouldn't seal. So I drilled and tapped a hole at the front of the head for the front flange of the header.
Takes:hillbilly: to know one!
LOL, no Mark not my genius work here. I wish I had that level of creativity! Good news is I WILL take this thing off. A friend is handy with the welder, so we may see if we can create an eyelet that will hold the manifold in place versus this contraption.
Lesson learned, if it aint in the FSM, it was probably "Bubba Tech"
Better to replace the exhaust manifold instead of rigging up some sort of clamp..
