manifold recommendations?
82 manifold setup is a good one, and will cause you the least amount of tinkering to get it to fit, considering that's what you've been running. Just post up in the wanted section, or check out all the 60s being parted in the For Sale section. Shouldn't be ANY problem finding another manifold of this vintage.
I doubt I could match a private party on $$.
Hth
Mark A.
could yours be planed? or are they to far gone?
My exhaust headers are welded to the system, so disassembly would mean cutting it apart. The flanges on the exhaust headers are thinner than the flanges on the stock inlet manifold that is fitted - though the inlet manifold has recessed holes. This seems to be the problem, as the leak is from the bottom of the exhaust headers where the studs/bolts do not have much purchase.
I would like to purchase the right bits before taking the guts of this beast apart so that I can do the job in a couple of hours, rather than being left with a broken truck and a box of bits.
Any help appreciated.
didn't someone have split washers, that were thicker on half, to fix this situation?
