Manifold heat shield mounting hardware
RyanTomorrow
Livin the livin.
Belmont, MA
While admiring @NLXTACY’s Instagram feed, I realized: hey, he’s got some heat shields under the hood that I didn’t even know I was missing! Turns out the PO took off the manifold heat shields and I never realized they were missing. I figured out where to source some new ones but I need to know what kind of hardware I’ll need to mount em up. Anyone know what bolts they take offhand?
Sure! I bet I need to order a few other things from you anyway, might as well save on shipping. Going to go the ceramic coating route on them.
Definitely take @NLXTACY up on used bolts if he has them, but otherwise they are M8 x 1.25 by 3/4" long.
Part numbers from Toyota are below. Hardware is in the small bag.
Mine have the common little cracks at the bolt but totally usable. For me I need to make s*** look good so I’m going the extra mile.
Small side question: why do all the heat shields crack at the bolts (heat cycles, vibration, metal too thin, fastener design??), and is there a fix to prevent cracking (Wits End Exhaust shield repair kit)?
For sure it’s heat cycles and expansion/contraction of dissimilar metals in a fixed/clamped location.
@NLXTACY do you carry the heat shield bolts? I took my heat shield off while chasing (another) exhaust leak and I dont want to put these crusty things back on. I'd rather give you the $$ when I get a few things I've had in my wits end cart for a month or two.
Partssouq wants $13 to ship $2 worth of bolts. Which don't get me wrong I am stupid enough to do.
Sorry to raise an old thread but I need to know what those sheilds bolt too: I assume there's tapped holes on the stock exhaust manifold itself? I wanted to buy some shields from Toyota but then I realised that the PO has aftermarket exhaust. Can the shields bolt to the open threads ok the side of the head?
Nope. You’ll need a custom solution
Bugger, thanks!
