Manifold Flange Surfacing
Are you looking for a “how to” video on how to do it yourself with hand tools? Or are you looking for a vid of a milling machine in action?
Sorry, I wasn't very clear.....I'm looking for machine shop video, preferably with a mill. I can find a few pics of the finished product but I would like to see the setup as it's being done.
I ended up surfacing my manifolds last night. I only had an end mill cutter to work with but it worked out ok. I had to take off .060 to get both manifolds clean & flat.
I was able to resurface my manifolds at home.... flat piece of aquarium glass with sandpaper stuck to it. Took lots of elbow and shoulder grease, but got a way out of spec intake/exhaust manifold back to within spec and eliminated a pretty significant exhaust leak.
One year In and the 2f is still purring like a kitten.
The manifolds are bolted together, keeping them in alignment. If it's a later exh and the swivel ends are not rusted solid, they get 2 tack welds to stop the rotation. The bolt holes are spotfaced after the face milled manifold is bolted to a straight head. Tack welds are ground away after machining.
I didn't tack weld on the outer exhaust ports. I machined each one separately after carefully measuring how much I needed to take off. If I had a longer mill table, welding them on would have been the way to go.
