Making Bumpers
Progress.
Ehsan, hes saying at the least, bore a hole straight into the larger cylinder at the point of the ball bearing and put a grease fitting in there, that way it wil work its way down the inner shaft as you grease it.
FYI: most guys are using a trailer spindle and wheel bearings. That way they are serviceable, and you can tighten them up after they get bounced around a while, and loosen up. Heres a link.
http://www.rockstomper.com/catalog/pieces/hinge.htm
Thank you for the explanation.We are working on an improved design with a curved grove on the insidefor the greese. Will post pics on Saturday.
Ehsan
The Rockstomper spindle is a little weak...............a Slee Offroad spindle is much stouter.
so did you make either one an air reservoir?
Nice work.
I like the spindle down approach.
How do you grease it? And won't the grease lift the pin.
Looks great but you have to get back to making my top.:grinpimp:
Kevin
There is a nipple from where grease can be pushed in using a grease gun. This hinge is very nicely made. Even without grease, taking the two parts of the hinge apart takes a considerable force due to air locked in.
Ehsan
PS.. Oh.. Your top is almost done. :)
