Mace said:Tapage, you fixed your camber issue with the SR conversion..
You think that it was better than getting a Spring lift and running shorter shackles to return your caster to proper specs???
Camber and caster are to diferent things .. I haven't any ( in any time ) camber issue in my HJ-60 ..
The caster issue is very important, in any lift, when you turn your diff up, to get a proper front drive shaft angle ..
In the past when I had SU configuration, I need to use the shims that comes with the kit, to get a proper caster degrees.
The original caster of my HJ-60 comes btw .84 to 2.43 positive caster always.
