MAF problem..please help 94 3.0 v6
Blandon Pa
Because of another issue I posted, I pulled out my MAF to check the contacts..STUPID! and i'm having all kinds of trouble putting it back in and now I'm confused on which three contacts go to which prong. The truck turns over but will not start. I've posted pictures. I'm not sure if its normal but some of the contacts look like they were broken already..please help. thank you
It looks like some of those contacts were soldered to the board inside.... If so, You're going to have to dig deeper to fix that.
As for where the wires go, my best suggestion is to do the ohm reading diagnostic tests and see if that gives you any leads.
That or find a new MAF! :D
Thanks for the help guys, I'm getting a used one on Friday. In the meantime I've changed the fuel filter and went over everything else, hopefully it takes care of the problem.
