MAF Adjustable Rear Panhard ?'s
Murrieta, CA
I have the lift up and on. Bled the brakes, drove it around a bit, and everything is nice. I need the CC bushings in still :)
My issue is.....
I know that the axle moves to the passenger side after the lift, and I have the rear panhard in, and I tried to adjust it "OUT" to push it towards the drivers side, and it won't move enough. I basically get to the end of the threads on the adjustable section, and it isn't enough.
Any insight??
Try flexing it out. You may find that you can't adjust the axle over to where you want before the tires start hitting things on compression. Depends on the tires of course, and YMMV.
-Spike
from your sig line it looks like you bought the kit from MAF.
Any insight??
don't expect much in the way of support. If the rod is at the end of it's adjustment then you shouldn't have been sold it for your setup. Since they have dropped the "drop bracket" you are probably out of luck as far as getting a solution from them.
A solution would be to get the "DIY" joint from Slee and then compensate for the added length needed by not cutting out as much of the rod as the directions say.
I think I am going to try to get the ass end of the truck up Monday so that the axle is basically floating. Then try to adjust it. I think right now, the tires are just flexing back and forth instead of the axle moving. I followed Slee directions for the install, since MAF doesn't come with ANYTHING as far as install help, and they say to set the panhard to 1/2" longer for the difference. There was enough to do that, but I need a little more. I will check it out Monday though.
You have to adjust the panhard at ride height. It helps with someone pushing the body sideways. You should not jack up the vehicle. The rod will push the body over, you are not trying to move the axle. 1/2" is normally pretty close to what you need. What are you measuring as a reference? Don't measure tires against body, you need to measure wheel mounting (or a common point on the axle) to frame. The body is not necessarily square on the frame.
The best way to do this is remove the wheels, put have the axle on jack stands (not the frame). Then measure by using a straight edge on the wheel mounting surface to the frame. Adjust until centered. Be careful doing this so you don't push the truck off the jackstands.
You want the axle to be centered at ride height, yes it might rub more on one side than the other when flexed, but that is the nature of a panhard at an angle when lifted. However getting the axle centered is more important for day to day driving and handling than where the tires rub on the trail.
Thanks Christo. I was measuring from the dust covers on the back of the rotor to the frame rail. It was an inch off. I adjusted it out till the threads on the panhard were loose. I didn't take the panhard apart. It didn't seem to be moving enough by the looks on the outside. The outside of the tire was basicaly flush with the flare on the Passenger side, and sucked in at the Drivers side. I will try it again today.
Thanks for the instruction PDF :D They were great
I look my rear bar off, rolled the truck down the driveway a few times, once around the cul-de-sac then let is settle over night. Next day the frame and axle where inline with each other, took a measurement and had it right in one shot. I guess I should say that the front was already corrected, so that might have help put the frame inline with the axles.
Is it the new panhard with the spherical end? You can adjust that with a wrench while it is installed. It should have plenty of thread - it is not designed to have to be used with the drop bracket.
I am running this very setup. A pic would help if you keep having issues.
Alright, I finally got it all worked out. I got the bar almost fully adjusted out, and it is reeeeeal close. I am going to leave it there for the time being. I was just too nervous about the amount of thread showing, and the fact that when I didn't have the jam nut tightened on there, I could shake the bar back and forth. It felt like there were about 3 threads left....you know that feeling?? Well, I got it out, tightened the nuts, and it is there to stay. Now, getting the CC bushings done, and an alignment (and tires) I am done. FINALLY
:eek: I don't think I'd trust it with only three or so threads left... even if it feels solid after tightening down the jam nuts... Yikes. I'd be on the phone with MAF gettin them to look into it....
Reminds of when Marlin first started making hi-steer for the FJ60... Everybody was getting the wrong length tie-rods... Marlin stood behind it and fixed everyone up once the correct length was figured out.
-Ferg-
You need to mark that rod and then unscrew it all the way to see how much thread is left. If it is really only three, then I would not run it that way.
Ditto that.
I'm not sure you were saying it felt that way before you tightened the jam nut, or it is that way. BUt you might want to check.
