M-416 Water Tank
Nice setup! Show me your propane bottle setup for this thing pls! Also, what's inside the top part of the unit? Is it for shower head/hose storage?
Thanks.
Those of you who have the Eccotemp shower units. do you use the switch at the shower head to turn it on/off while you're showering? If so, is the water temp pretty consistent, as in no scalding on startup?
Thanks.
Water temps were perfect. Once you get it set you don't have to touch it. Very nice unit. Worked flawlessly. I will say that they don't like anything over about 50 psi so if you use it in a camp ground hooked to a water faucet, use a pressure regulator (40 psi). I have used the Zodi set up as well and it doesn't even compare to this unit.
Later,
Thanks.
I just cary a small bottle of gas (10lb.) and it attaches to the bottom of the unit. The unit comes with a hose and regulator with a standard propane fitting.
The bottom of the unit is the burner and the top is the heat exchanger. There is no storage "in" the unit it self
