Some fender/bumper trimming to fit bigger tires?
Since I'm moving to larger than 35s I ran into the issue with the windshield washer tank. I think I want to make a 1" shorter tank that fits in the OEM area that retains all the stock pumps\sensors. So I scanned the area after my inner fender raise.View attachment 4145068
Unfortunately not enough for my situation. I cut off the rear mount and the locating pins and was able to shove it up a good amount but the tire still runs into the tank at bump.The stock washer tank is surpisingly complex with the number of pumps and interfaces.
It's a game of millimeters and there's a couple things you can do to increase tire clearance against the tank. Not sure if it will be enough.
The tank is hung on the inner fender and has about a 1/2" clearance all around. I imagine it can be mounted higher up against the outer fender. There's another 3/8" to glean from the re-routing of the hoses underneath. I relocated them to the relief channel with some tie wrap ankers and shaved stock plastic guide hangers off.
I think that is due to the longer suspension arms from the Tundra.I'm impressed that you're doing this without a body lift. Also seems like the Kings can accommodate some more uptravel?
