LX450 noob thread
I have never posted on a forum and have no idea what I am doing. So I guess i'll just post my question here? I am new to the Lexus/ Toyota scene, I was recently looking at a 85' SR5 ext cab but I ended up leaning more towards a 1996 LX450. What are some general maintenance things to look for? I've heard of the "PHH" problem but that's about all I know. Any guidance would be greatly appreciated, the vehicle is a 1996 LX450 with 164k miles, seems mainly street driven(no lift or even all-terrain tires) interior is very nice from what the pics are showing. I am going tomorrow to look at the vehicle in person, they're asking 4k obo, just so everyone knows, its located in el paso so not the most wealthy community. Is this a good price? I did the typical KBB check and they said around 3800 for GOOD condition. Please help and sorry for being a newbie
That's cool the 3 post above me posted the samething.
Here in the central valley of California it would go for 8K easy.
WELCOME.
I bought mine with a salvaged title for 5600.
168K miles w/lockers.
Thanks for the help everyone! I read the article and it was fairly informative but yet it suggested nothing about that heater hose problem? I want to know what your personal failures have been and if it is a common thing, I think I remember watching some video that mentions some gear or part in the driveshaft I belive that needs to be cleaned but that most people don't know that?
Hey give my hometown Hell Paso a big hug for me!! It's been a while.
i have a 96 LX450 i purchased for $4k with a 124k miles on it. this is what i have done since i purchased it: approximate costs from memory
• front axle rebuild - $1200
• rear axle rebuild - don't remember
• head gasket, timing chain, both oil pan re seal, oil pump, distributor orig,valve cover gasket, head rebuild,injectors went out for cleaning , new water pump, belts, tensioners, fuel filter, vsv , vcv, all the vacuum lines associated to those, all toyota parts around - $3k
• all new brakes and rotors - 600?
• transmission flush - 120
• brake fluid flush - 100
• power steering flush - 36?
• new plugs , wires, rotor and cap - don't remember - all toyota parts
• springs and shocks (ome) 1300? plus the install was 6 hours labor?
i dont know if that is everything but its close
currently 142k miles , doesnt include the upgrades
planned :
seat belt rebuild
new interior
rebuild front suspension
water injection maybe
drawer system
por 15 undercoat
full exhaust and cats
body bushings
Was that just because those parts needed repair? Or was that preventative maintenance? I am able to do all the work from my garage if needed, my neighbor is a master welder also so he can help with any metal fab.
Will do 1997LX450! I've lived in Las Cruces most my life but Key West is my hometown! Any Flordanians out there?
http://www.sleeoffroad.com/technical/tz_heater_hose.htm
https://forum.ih8mud.com/threads/phh-and-cooling-system-overhaul.820118/
https://forum.ih8mud.com/threads/phh-oem-style-close-up-pics.818308/
https://forum.ih8mud.com/threads/phh-thermostat-replacement-radiator-flush-complete.814272/
https://forum.ih8mud.com/threads/phh.6994/
UPDATE: I went and saw the vehicle today, the current owner only had it for 7 months, they initially bought it for his sister but she struggled to turn the behemoth so he is selling it. Unfortunatly I forgot to take pics to show you guys but here is a list of everything good and bad I noticed about the truck.
BAD:
  • Was rear ended and the
BAD:
  • Was rear ended and current owner thought it was so "symetrical" he didn't notice it was a dent until he saw another Lexus
  • Passenger side tires, front and rear have significantly more wear than drivers side
  • Windshield is cracked (guy quoted some person in town will come to your house and fix for 100$)
  • Front has small dent in bumper, not that big at all
  • 2nd row seat was ripped fairly bad, owner things it was maybe a car seat because its only one side
  • Speedometer doesnt work, guy has the sensor to replace it though
  • Power antane doesn't go up or down, not that big to me but still something broke.
  • Knuckles had some grease on them, not heavy all over but some areas had a thick layer
  • One hose up front looked like it was bulging and melting, i have no idea what hose it went i think it went to the radiator
GOOD: This list is going to be smaller because I dont know what is a GOOD thing to look for on these vehicles
  • Engine sounded fine
  • Transmission shifts good
  • 4 wheel drive engages
  • All power features work
  • Spare tire has all its tread
  • No leaks coming from the engine or transmission
  • AC/Heater work almost TOO good
  • Brakes worked fairly well for a 5000 pound vehicle
ODD:
  • I wasn't sure if a new radiator was a good thing or bad so here it is
  • When the headlights are OFF and I apply brakes the gauge cluster becomes lit up, not very bright but noticeable
Thanks,
Isaac
The vehicle is nearly 20 years old so many factors will play into what needs to be done right now but surely lots of work will need to be done eventually. They are great machines but all machines have a life expectancy and will require maintenance and refurbishment. What I'm saying is that you can expect to do a lot. How much money you spend depends on where you get your parts and how much of the work you do yourself. Your original question has to many variables to be answered directly.
What of the bad things that I listed should be prioritized?
Get the frame checked from the accident. That could also lead to tire wear. If the frame is straight the tire wear could just be its out of alignment.
The rest are small things IMHO.
The frame is straight it still has a clear title, it would just need a new rear bumper if I felt like replacing it. Ill run a carfax on it later today, ill be heading down around 6 PM MST and ill post some pictures!
