Lx 570 engine covers
I’ll probably end up doing a similar cut in the near future, but I might even extend them back a little farther. Going onboard compressor so less need to access the battery. Might cut right at the edge of the airbox and fusebox.
Going to the airbox blocks the power steering reservoir, but most people don't access it often. We did the battery-side cut at the slot built into the factory panel, which seems to be to help cool the battery or something along those lines.
Just to be clear this also trimmed the center panel. Usually it hides the radiator and belts, and only marginally displays the coolant overflow bottle.
My solution to this was simply leaving all the clips out.
Takes 10 seconds in a gas station parking lot to check oil and fluid levels realign the panels and shut the hood.
Granted I did this out of pure laziness. But the panels haven't moved at all with zero clips in for a year now.
That’s actually an excellent low tech idea.
Objectively a great idea. I don’t think my compulsive brain could handle the idea that they MIGHT be rattling under there, even if I can’t hear them.
+1 For not installing the clips. Since the covers bridge from front to back and can really only fit in one way, i can't see how it matters that much. The gasket between the hood and core support should keep them pressed down enough to stop any bouncing around if you were worried about that sort of thing.
I was the Guinea Pig today…
Chose this cutting point based upon being able to still clip the two sides (behind the washer fluid filler & on the other side as well.)
Used painters tape, utility knife, & tin snips.
This makes me regret tossing mine 🤦🏻‍♂️
I’m considering cutting them down another 10” or so, making them flush with the center section. Also would make it easier to get to the battery terminals to jump another car if needed.
Will run them for a bit and see what happens
Nicely done and that looks good!
The things I tend to access more underhood is the air filter after trail runs to either replace or blow out silt. Next thing that is not a regular need by a long shot would be better access to the battery, which still looks largely covered.
Thinking along the lines of @mceagle555
I did a little modification to my engine bay covers. Did a little trimming for passenger side one for the Slee mount and Voswitch box. Driver’s side I hogged off a huge chunk for the ARB twin. Oscillating multitool makes quick work of plastic stuff like this. Yeah, I know it’s dusty.
Does anyone have the part numbers for these plastic covers? When I search "engine covers" on the parts websites I get things like that metal cover over the actual cylinders, or other parts of the actual engine, nothing that seems to be the plastic covers themselves. Mine is missing one of the side ones and it sounds from the discussion like it is kind of important for air flow, etc.
Thank you!
Thank you!
they are called engine room covers in the parts catalog
We could have done a better job of aligning the new back edge of the center piece with the new back edge of the side.. but it works.
Ooh, I like this. I bought my 2015 LX in January. I say a few minor curse words every time I need to do something under the hood, like check fluids, filters, access the battery for air up purposes. I really hate the LX full engine bay covers. (I have the same crap on my '08 ES350 and hate them as well) Nearly all the clips were missing when I purchased it so I bought a large bag of aftermarket clips from Amazon. But I want to see all the engine bits every time I open the hood to monitor for leaks or other problems and not have to remove the covers every time. But I also live in NM, drive steep mountain terrain regularly and tow my 5K lbs travel trailer regularly. I don't want to do anything to impact the airflow and cooling effectiveness.
