Lug Nut Torque With Alloys?
San Diego
Website
youtube.com
done some searching, FSM says "securely" some people say 80 some say 100lbs
what is the consensus on here?
93 FZJ80 with the stock Alloys
thanks
76 ft lbs
edit: oops! Gave you the number for my year...
Depends on the year.
94 and prior, with conical steel inserts are 109 lb-ft.
95-up with shank lugs are 76 lb-ft.
The guys at discount tire misread the chart and went to 109 lbs on my 96. Snaped 2 lugs right off. They took care of it but what a hassel!
76lbs for alloy
76lbs for alloy
This doesn't make sense but I've heard it several times before. Wheel studs in good shape should not snap at 109#. The OEM steelies are the "stock" wheel; the alloys are an "option." The steelies torque at #110 (IIRC) So why would the studs not be able to handle this torque regardless of which wheel is being used?
For the record, I am NOT suggesting anyone torque alloys beyond spec (76# in my case.)
-B-
ahhhh thanks
too bad my torque wrench only goes to 90 lbs :frown:
Buy a bigger one?
cruiserdan said:
Buy a bigger one?
Definitely buy a bigger one, most measuring devices are inaccurate at their extreme ranges. You must be using a 3/8" drive, you'll be much happier with the extra leverage of a 1/2" wrench anyway.
-Spike
cruiserdan said:
Buy a bigger one?
Yeah, unfortunately, it has been perfect until this! :D
